Volt Gauge
Old Jun 19, 2019 | 09:30 PM
hyprr1's Avatar
hyprr1
Default Volt Gauge
Hey guys, i wanted to monitor my voltage so I installed a volt gauge.
My bike's usually hooked up to a trickle charger. I had this gauge lying around so I wired it directly to the battery with a fuse (It'll always show current voltage).
Mounted the gauge behind the seat so no high heat gets to it.
What do you guys think?
Taking my bike to the shop tomorrow to get the carb cleaned and adjusted.
Old Jun 19, 2019 | 10:15 PM
TriGeezer's Avatar
TriGeezer
Did you ensure it’s accurate?
Old Jun 19, 2019 | 10:40 PM
hyprr1's Avatar
hyprr1
I actually went back into the garage and rewired it to my ignition.
Earlier today I had it connected directly to my battery (volt meter would be reading all the time, even when the bike's off).
Probably would of slowly drained my battery.
I think it's pretty accurate.
We'll see in the upcoming days.....
Old Jun 20, 2019 | 07:27 AM
Chunker's Avatar
Chunker
If you have a reliable multimeter you can check the incoming voltage to the guage to know whether it's accurate. Yes a guage hot wired would drain the battery eventually.
Old Oct 28, 2019 | 10:43 AM
hyprr1's Avatar
hyprr1
I thought I’d share this with you guys…..
Recently, I bought this Volt gauge off eBay and I couldn’t find a spot to mount it on my FatBoy?
Found a spot behind the seat but that was no good because obviously I couldn’t see it.
So, I decided to do some drilling & dremeling.
The gauge is dead on accurate (checked with my multimeter). The two switches are for future “Love Jugs” and Fogs.
whyrzwaldo
Apr 21, 2015 10:10 AM
jwaldo
Apr 10, 2014 05:17 PM
Keithhu
May 10, 2013 09:15 PM
TennesseeEG
Apr 5, 2012 09:34 PM
FLHTCUI05
Electrical/Lighting/Alarm
Sep 22, 2011 07:13 AM
