Hey guys I am trying to run the best map for my 2014 softail slim. They have all my parts in the system except for the type of pipes I have . I have Bassani pro streets turn outs and although they have Bassani pipes they dont have pro streets. Neither company seems to know what to pick. VandH said pick their short shots and Bassani said use the Firesweep choice. Has anyone went though this or something similar. Thanks
Pick one set the map then do an auto tune.
You have to put some time/miles into it.
While you are riding you can see the blocks turn to yellow then green.
Depending on your riding style depends on how long it takes.
If your riding varies allot it takes longer.
You can also U-Tube it get a better idea.
While doing a quick search I also ran into this:
Double check your Fuel Pak firmware and make sure it's up to date, mine shows a listing for Basani Turn-Out 2-2 for a 2014 Softail.
Your FuelPAK holds multiple maps, try a few and test ride each one.
do you think this is better than the Firesweep ? I have the PRo St.
