S&S teardrop for EFI
Old Jul 30, 2019 | 09:28 AM
Dieselvol's Avatar
Dieselvol
Default S&S teardrop for EFI
2007 Deluxe which, I think, is at stage 3? I’ve got the stage 2 intake, bigger cams, true dual exhaust, and the Harley programmer. I’m thinking of adding the S&S teardrop for EFI, mainly just for looks. They say it’s a an upgrade over the stock intake and implied that a remap would not be necessary if you already have an upgraded breather. Is this true? I don’t mind the cost of the new breather, but the added cost of a remap makes the change not worth it to me. Also, is there any way to just put an S&S cover on what I’ve already got? That’d be a ton cheaper and a lot less trouble if I could. Thanks.
Old Jul 30, 2019 | 12:23 PM
XARAN's Avatar
XARAN
if you alrerady have a hi flow A/C you are fine the S&S or any other High Flow will be the same and not require a Dyno or new MAP.
Old Jul 30, 2019 | 03:02 PM
Dieselvol's Avatar
Dieselvol
Cool. Thanks for the help.
Old Jul 30, 2019 | 06:50 PM
Gas Smasher's Avatar
Gas Smasher
I don't know if you could use just the cover, there are some brackets that hold the element and allow for the cover screws. Like XARAN said, if you have a high flow already it won't change anything for you.
I have one on my 2002 Fat Boy. I like it. It provides a little more protection than a lot of the open ones if you get caught in a heavy rain storm too.
