Throttle Hesitation from Low RPM
Old 09-21-2019, 09:51 PM
springers4ever's Avatar
springers4ever
springers4ever is offline
Talking Must have misunderstood ...
Originally Posted by manleydawg08
Can you educate me on this? I took the crank breather hose from the oil pump out of the air cleaner port. Why when I take away more air going into carb would that make it leaner? I would think , again I’m a rookie at this, taking away air would richen it out? I was tired of it spitting oil on my bags on trips . Now it goes to a filter .
Sorry but i Must have misunderstood ...i thought you meant you took the breather hose loose from the the carb ...(oil mist to intake will richen mixer)
but i see you are saying now you suspect the accel pump leaking ...please disregard...
Old 09-21-2019, 10:01 PM
manleydawg08's Avatar
manleydawg08
manleydawg08 is offline
Maybe we’re taking about same hose. House coming out of oil pump , I believe is crank case vent was hooked to side of air cleaner . It would just most oil in the bottom of air cleaner and mist all over bike . Your saying that being hooked up will allow more rich? I have it hooked up to to a filter mounted to transmission case to catch the oil most . Seen it on other bikes hoping to prevent oil misting .
But yes diaphragm was bad worn out and had a slit in it . Hoping don’t have to hook crank vent line back up to air cleaner . Not getting oil misting on bike anymore lol
Old 09-22-2019, 03:07 PM
manleydawg08
Default Update....
Good news / bad news. Lol
no more gas leaks. But hesitation still there. I went ahead and hooked back up the oil pump vent line back up to air cleaner to make sure that wasn’t is, since only change I’ve made.
Hesitation is only if i snap throttle at idle or down shifting . Runs great accelerating and riding and I snap throttle. Down shifting and idle.
One member said maybe float float out of adjustment ? It’s so minor it’s frustrating lol. Could be worse I suppose but just want it right . When I snap throttle at idle , I hear the carb suck and then go.
Probably wont mess with it till winter as I want to ride , but looking for advice . Seafoam been through carb twice , it’s something silly lol
one last thing, I did spray starter fluid on manifolds and my idle no longer changes .. so diaphragm May have fixed that too
Old 09-22-2019, 07:23 PM
manleydawg08
Default Fixed !!! SMH
I forgot to mention that I replaced the plugs . Took our new ones and the gap was .503 ish . My old ones were .40. Well I moved them down to about same and the hesitation went away , coughed a couple times but that was normal . SMH. Going to order new plugs from dealer since they gap was so large. Don’t think I’m supposed to move the gap that much .. anyway I think that was my problem .. thanks everyone.. I did fix the diaphragm!! Sorry to bother
trussham
Carburetor Related
05-01-2015 05:30 PM
ptcruiser
EVO
06-10-2012 12:11 AM
guitarbug
01-19-2009 04:07 PM
MAX EVO
Exhaust System Topics
06-25-2008 07:45 PM
Xguy
23
05-28-2008 02:37 PM
Quick Reply: Throttle Hesitation from Low RPM
