Clutch cable problem on my Heritage after bar install
Old Nov 12, 2019 | 03:47 PM
cruzomatic's Avatar
cruzomatic
Default Clutch cable problem on my Heritage after bar install
I installed some 14" Carlini's on my 2012 Heritage. I was getting some forward creep on my clutch so I took it into the dealer for clutch adjustment. All has been good, but with my last ride it has all gone bad. During the ride, I notice my clutch cable became really loose and would not engage when pulling it in, this was while underway at about 65mph. I pulled on the cable itself, the lining and it all seemed to work ok after that. After getting it home I adjusted the cable (Magnum) to take a little slack out of it. Then this past Sunday after about 20 miles I again had no clutch, thank God it happened as I was getting home. I called the dealership today and they told me to take it in. I tried to get it started and no way I could get it there as it wouldn't even go into 2nd gear. I let it die on it's own, after hard shifting into 1st, I had no clutch. I was only a couple hundred yards from home and had to push it back home from down the street.
Thoughts on what it could be please? I'll need to trailer it if I take it in, but I'd like to have a go at it myself. I just can't get the cable to tighten enough, taking the slack out of it allowing that little play of the lever.
Thanks,,,
Adrian
Old Nov 12, 2019 | 05:34 PM
RANGER73's Avatar
RANGER73
First it disengages when you pull it in.
The original problem was probably it binding and it corrected itself.
Could of been a burr on the clutch rod.
Old Nov 12, 2019 | 05:57 PM
cruzomatic's Avatar
cruzomatic
When I took it from the dealership it was perfect. After I went on a long ride it went limp on the road. I took that slack out from the adjustment on the cable and now it's all messed up. Now I can't get the slack out at all.
Old Nov 12, 2019 | 07:42 PM
cruzomatic's Avatar
cruzomatic
I'll post some pics.
Old Nov 12, 2019 | 07:58 PM
cruzomatic's Avatar
cruzomatic
Old Nov 13, 2019 | 05:27 AM
RANGER73's Avatar
RANGER73
Could be the clip in the transmission snapped off and the plate the holds the ***** twisted.
Who installed the new clutch cable? Or do you have an EZ clutch installed?
Old Nov 13, 2019 | 06:53 AM
cruzomatic's Avatar
cruzomatic
I installed the clutch cable.
Old Nov 13, 2019 | 08:34 AM
hattitude's Avatar
hattitude
As Ranger73 suggests.....
If you have the time/knowledge, I would open the clutch release cover and check the inner & outer clutch ramps....
Look at #18, 27, 13, 28, & 33....
Old Nov 13, 2019 | 09:03 AM
cruzomatic's Avatar
cruzomatic
Ok, thanks, I'll get to work soon .
Old Nov 13, 2019 | 09:08 AM
RANGER73's Avatar
RANGER73
And don't go by this blow-up. #18 goes on top of #28 to hold it in place.
