Saddlebag lights
Old Dec 5, 2019 | 08:18 PM
darrelld1967's Avatar
darrelld1967
3rd Gear
Default Saddlebag lights
Have a 2000 softail bagger trying to put on saddlebag lights on #67800241A- ELECTRA GLO SADDLEBAG LIGHT bike does not have the newer connection wonder if I could hardwire it
Old Dec 6, 2019 | 05:34 AM
Hammerhead Pat's Avatar
Hammerhead Pat
On my 2011 FLHR I added a tourpack and hardwired my side marker lights into my run / turn / brake controller and have no Issues. I say give it a go....
Old Dec 6, 2019 | 11:32 AM
darrelld1967
3rd Gear
my question to you is I have Two plugs going into the controller that controls the lights one in and one out how do I hardwire my lights to that
Old Dec 7, 2019 | 06:23 AM
Hammerhead Pat
What I did was use a test light to find which wire lit each turn signal and tapped into it ( seeing as I have the r/t/b setup ) that wire will also activate my brake lights. Then I tied the ground wires together and used a bolt on the frame as a ground...
Old Dec 7, 2019 | 06:29 AM
Hammerhead Pat
Also, were you looking to make these function as r/t/b? If you only want them to be a running light, see if you have an orange wire with a white stripe on it back there, on a lot of our bikes that is a switched power wire you could tie into. Look for it and test with ignition on...
Old Dec 7, 2019 | 06:20 PM
darrelld1967
3rd Gear
OK yes but I do want to run/t/b
darrelld1967
3rd Gear
FDHOG
Sep 27, 2019 01:33 PM
dasimmons24
2014-2024 Touring Models
41
Jun 18, 2019 05:00 AM
Oldpaps
Electrical/Lighting/Alarm
Feb 28, 2019 12:42 PM
mike79
Apr 29, 2018 09:17 AM
clackavosticus
Sep 30, 2015 06:00 PM
