Front brake locked up!
Old Dec 17, 2019 | 07:43 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Is it a single sided caliper? If so it could also be the pins the caliper slides on.
Once a problem is encountered with the braking system I would be inclined to strip it all down for a thorough inspection and clean replacing worn parts as necessary.
Old Dec 17, 2019 | 01:38 PM
Jerry L's Avatar
Jerry L
Well, I measured the front rotor thickness and it's only .190" and replacement is at .180" so a new rotor is in play too. I think with the rotor worn (probably from sticking caliper) and worn pads, that the caliper pistons came out too far and got stuck. I'm going to get a caliper rebuild kit with new pads and rotor, and i think that should do it. Also, I"ve been trying to find out the diameter of the front rotor, is it 11.5" or 11.8? My service manual is on it's way, but if anyone knows, i'd appreciate it!
stephtell
EVO
29
Oct 21, 2017 07:09 PM
dustydog2
Mar 21, 2015 12:32 AM
that$pit
Feb 9, 2015 01:19 PM
KiloGolf4
Aug 24, 2012 07:58 PM
lunyty1
Mar 3, 2012 10:30 AM
