Engine light coming on
Thanks
Louie
https://www.hdforums.com/how-tos/a/h...e-codes-413169
Thanks
Louie
As mentioned a common problem for intermittent codes on the older bikes would be from bad wires/plugs/ coil to plug connection... If I remember correctly, the code would read; "Front (or Rear) cylinder combustion intermittent" or "Front (or Rear) cylinder no combustion". I had that code/problem with my '03 Heritage and new wires fixed the issue...
FWIW...
When the check engine light stays on, you have a current code (problem) with the bike...
If the problem is intermittent, it will stay on while the problem is present, and go off when the problem has passed...
Once your bike throws a code, the engine light will come on and go off as normal, and then come on again for several seconds right after start up... this is a signal that you have a non-current, historical code....
Good luck with diagnosis/repair....
