Softail Primary clunk
Old Jun 14, 2020 | 03:21 PM
TheOrg's Avatar
TheOrg
Default Softail Primary clunk
I have an 07 softail and since fitting a Screaming Eagle HD compensator I get a clunking which sounds like its coming from clutch at tick over when cold, I’ve covered over 6,000 k’s with this prob and have stripped both compensator and clutch assembly several times and can find nothing wrong, I’ve replaced the tensioner as well
Old Jun 14, 2020 | 05:11 PM
LenBoyLo's Avatar
LenBoyLo
Default Primary clunk or click?
You may find a difference using a different oil in the primary. Several in this forum have switched over to using type F auto transmission fluid, Dexron grades. Me personally I use B+M trick shift. Most of us can tell you that there is less drag in the clutch plates that can be heard when putting the trans in first gear. Thus less clunk. I find reduced shift noise through all gears. Not certain what your "click" is but do the research and possibly try the above suggestion on different oil in your primary. You may be surprised. Best of luck.
Old Jun 14, 2020 | 11:54 PM
The Org's Avatar
The Org
Stage II
Cheers for that cobber, I'll give that a go
66Triumph
Dec 21, 2014 07:58 PM
Tim2
Apr 13, 2013 02:05 PM
Vetman
Sep 5, 2010 09:21 AM
55chevysa
Aug 27, 2009 10:11 AM
Rubber 21
Feb 27, 2008 10:02 PM
