front braking problem
Old Jun 29, 2020 | 10:43 PM
Billy Blaze's Avatar
Billy Blaze
Default front braking problem
Hey guys, first I tried to search this before posting with no luck, dont know if my search term skills suck or what but it is what iy is.
I have a new to me 09 heritage softail and the front brakes are pulsing / grabbing bad enough that even with my 49 years of ridding 2 wheels I am nervous about dropping the bike coming to a stop.
In addition when I pull in the front brake ;ever there's a audible squeak that may or may not have anything to do with it, not your typical brake lever squeak but louder anyway, I looked at the rotar and I am pretty good at seeing straight lines and dont see anything bent but do understand that even a miniscule bend could be causing this.
So my question is have any of you guys riding these bikes had a similar issue to help me isolate the problem?
and thanks so much ahead of time, I have a broken hip and dont need to dump my bike at a stop sign, it brakes fine other than pulsing at a stop.
Thanks again, I plan on bringing it to Harley soon if I cant figure it out.and fix it myself
Old Jun 29, 2020 | 11:19 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Most likely a warped rotor. Squeak and all!
Old Jun 29, 2020 | 11:31 PM
MyFavRk's Avatar
MyFavRk
Most likely the culprit . While your at it , have a look at your break pads and replace them if necessary . Go another step further and clean up your calipers and cylinders . Put a small layer of anti seize on the back of the pads and the pins as well .
Old Jun 30, 2020 | 12:20 AM
Billy Blaze
no squeaks
Old Jun 30, 2020 | 12:22 AM
Billy Blaze
will do and thanks, will try that out just priced out a new rotor and pads not too bad if I do it myslef.
So you think the brake lever loud squeaking is normal?
Old Jun 30, 2020 | 07:30 AM
MyFavRk's Avatar
MyFavRk
No , not normal . The only thing I can think of that could be causing your " squeak " would be the pivot pin or pin bushing . If you look under the lever you'll see a retaining lock ring , you'll have to remove that and check the bushing for wear . It could be warn out or dry . If it looks good , clean it up and add a thin coat of anti seize or grease .
Old Jul 1, 2020 | 04:33 PM
Billy Blaze
it sounds like its coming from the rubber around the internal switch.
I have some new levers to install so I will get a better look at it when I take the old ones off, could be a tear binding up on that rubber boot or something
Old Jul 1, 2020 | 04:42 PM
MyFavRk's Avatar
MyFavRk
If you can , see if you can get a little de electric grease in it or just wipe a little bit in the rubber seal , may help .
mjwebb
Milwaukee Eight (M8)
30
Sep 14, 2017 09:22 AM
FatRakoon
Aug 8, 2017 07:23 PM
Failuretolaunch
Nov 21, 2013 08:45 PM
russell6hp
Oct 2, 2009 05:31 AM
whitrt
May 2, 2009 11:44 AM
