Hi all, my 1999 softail standard has just developed gear change issues.
changing up from 2nd to 3rd the gear shift does not return to its usual position, but stays upwards.
It may drop or I need to change down then back up again.
Anyone had this problem?
I was watching a video about adjustments in the trans and I believe there's a spring that returns the lever to center.
Also a bolt that locks the shift lever to the shaft.
First thing I'd do is re-adjust the clutch pack, and adjust the cable. Pay attention to the fluid level.
Doesn't get it, good chance the pawl needs addressed. That's a pia.
