RPMs Rises as Bike Idles
Old Sep 11, 2020 | 04:25 PM
swifty's Avatar
swifty
Default RPMs Rises as Bike Idles
It's a 2013 Heritage, only work ever done was stage 1. Bike now has 30,000 miles, never a problem. Bike will run fine, but at a traffic light or if we are pulled over and put the bike in neutral, every once in a while, it will rise by itself from 1000 RPMs to 1500 RPMs. As it rises to 1500 rpms, if you just give it a little gas, bike will stall out. Bike does not throw any codes.
Any suggestions on what might be the problem?
Thanks in Advance
Swifty
Old Sep 11, 2020 | 04:42 PM
Hoginedgewood's Avatar
Hoginedgewood
Ooo ooooo! Intake leak?
Old Sep 11, 2020 | 06:40 PM
jkinner's Avatar
jkinner
Worth a try, disconnect the battery for about 5 min that should reset the ECU. see if it clears up. Good luck.
Old Sep 11, 2020 | 06:48 PM
NORTY FLATZ's Avatar
NORTY FLATZ
/thread.
or throttle position sensor
Old Sep 11, 2020 | 09:05 PM
JustDave13's Avatar
JustDave13
My 2013 has an intake leak that I verified with a shot of brake clean. It's Heritage with about 55k on the clock.
Same symptoms.
BTW I pulled the tank for easy access.
Old Sep 12, 2020 | 08:41 PM
swifty's Avatar
swifty
Thanks for all of the tips.. I checked for a intake leak and the bike is fine, no leak. Bike ran great for 80 miles today and then it started again . We took the bike to Danbury Harley and I will let you guys know what they say. Btw this is not my bike but the bike of a good friend that i ride with... Thanks again swifty
Old Oct 4, 2020 | 06:56 PM
swifty's Avatar
swifty
Ok so we got the bike back and all is well. Big thanks to Danbury Harley for getting us back on the road , turns out the problem was the IAC { Intake air control} The part is only 50 bucks but you have to lift the tank to do it!!! Thanks again to Danbury Harley... hope this post helps someone one day..... Swifty
dxn2
Oct 22, 2019 06:07 PM
Rev 86
Mar 29, 2015 11:26 PM
tekeum
Jul 10, 2011 08:57 AM
pingman68
Nov 26, 2007 11:04 AM
Rick51
Jul 3, 2006 01:25 AM
