2000 88 heritage soft tail
The 2000 I had & my 03 show a qt low on the stick after sitting for a week
Age old problem
Ride it. Get it hot. I'm sure the oil level will be right up there
I would suggest that if your oil tank drained into the sump, overnight, you have a problem worth investigating... Over the course of a few weeks or months, just run it easy until it's warmed up and the oil is circulating as designed...
After setting unused for a time, and the oil doesn't measure (or measures real low) on the dipstick, start the bike..... let it idle for a couple minutes... shut it off and then recheck the oil.. Most, if not all the oil will be pumped backed into the oil tank... If not, let it idle for another couple minutes, stop and recheck the oil.
This will give you an idea of how long it takes for your particular bike to scavenge the oil from the sump, back to the tank... Then in the future, any time you let it set for as period of time, you will want to ride easily, low rpm, for the amount of time it took for your bike to scavenge the oil back to the tank... Then you will know the oil system is functioning as it was designed...
These bikes drain oil into the sump for various reasons that range from; time since last start, to different oil pump tolerances, to worn oil pump, all the way to damaged oil pump/cam plate. Most cases it's the first three...
I can only see running it until it scavenges the oil leading to a problem if you started it up, and within seconds, started to "ride it like you stole it."
That could lead to increased crank case pressures, rotating parts whipping up the oil causing aeration thus poor lubrication/flow, and possibly causing rapid heat build up and power loss like in an active sumping situation...
Quick story:
One time, I hadn't ridden my '03 Heritage for several months (probably 6-7 months) due to an injury. I checked, and it was over a quart low... I put a quart in, and prepared for a ride...
It was idling for about 3-4 minutes as I got ready... When I started to ride away, my dipstick popped off, and the top of my oil tank looked like an oil volcano...!! That's how I learned of this nasty little quirk about softails... Mine hasn't done it since, even after "resting" for up to a month at a time... they will all drain & recover at different rates...
Now I always check my softails' oil level after they are warmed up (per recommendations), and if they haven't been ridden in awhile, I just let it idle for several minutes and ride easy for the first few miles...
Never a problem since..
