Fatboy torx bolt size
Old Oct 22, 2020 | 09:14 PM
DaveTV's Avatar
DaveTV
5th Gear
Default Fatboy torx bolt size
I attempted a search for this but did not find anything (yes I am a newbie). I am trying to mount up my brackets for the footrest on the rear brake pedal side of my Fatboy. I have tried to use a T-45 but it seems a bit loose. Curious if anyone has tried a Torx key that lies between the T-45 and T-50 range. Also does anyone have any info on these bolts, I was thinking of getting Allen key bolts to replace the Torx ones?
Old Oct 22, 2020 | 10:44 PM
Bone Doc's Avatar
Bone Doc
Welcome to the forum from central Texas.
There is a T47 Torx bit. If the Torx set is large enough, chances are it has a T47. You can only try it to see if it fits. Also, many of us have replaced Torx with Allen bolts. The problem most people have with Torx is they use the wrong bit or a cheap bit and strip the screw/bolt.
Ride safe.
Old Oct 22, 2020 | 10:51 PM
DaveTV's Avatar
DaveTV
5th Gear
Got it......do you think it would be best to switch them out and where did you get yours? Or if it is an if it isn't broke don't fix it issue?
Old Oct 22, 2020 | 11:17 PM
Bone Doc's Avatar
Bone Doc
I think it is more of an individual decision. Personally, I do not have a problem with Torx. There is absolutely nothing wrong with changing to Allen bolts. My main issue is not with Torx but button head bolts. I do not like button head bolts because it can be difficult to get locking pliers to grab them due to the rounded head should the bolt strip. For that reason I change to socket head Allen bolts.
My main go to for fasteners is Allens Fasteners. There is also Alloy Boltz, Bolt Depot, Fastener Warehouse and Fastenal. If you can't find a fastener at one of these sites then they don't make it.
Old Oct 23, 2020 | 07:52 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
There is nothing wrong with Torx fasteners, like Bone Doc says, the problem is when the wrong size tool is used.
Always look up the fastener in the parts manual, so you know the correct size, and (very important), the grade of the fastener.
A lot of the stuff you will find at a home center is ungraded el cheapo junk.
Also keep in mind that stainless fasteners used in aluminum is not a good mix.
Tom Koopmann
Sep 12, 2020 12:13 PM
dansax
General Topics/Tech Tips
May 30, 2016 05:53 PM
rclare
May 27, 2010 08:38 AM
anubisss
Dec 11, 2007 10:11 AM
Johneb48
Aug 15, 2007 10:20 AM
