Question without an answer? Desperately needing help!
Old Oct 27, 2020 | 04:45 PM
rb5064's Avatar
rb5064
Originally Posted by bustergut
This is the original front turn signal on a 2005 Fat Boy.
The wire didn't feed through the original mounting (part 12 RHS & part 13 LHS), which seems to agree with your photos.
The wire doesn't go through the stud. In one of the above photos, you can see the wire goes into the nacelle behind the turn signal.
Old Oct 27, 2020 | 04:54 PM
rb5064's Avatar
rb5064
The wire doesn't go through the stud. In one of the above photos, you can see the wire goes into the nacelle behind the turn signal. This exploded view is actually helpful. I will pull the lens off one of the turn signals and remove the bulb to check if the nut (# 4) is inside of the turn signal housing. Thanks for the diagram!
Old Oct 27, 2020 | 05:24 PM
bustergut's Avatar
bustergut
One good look is worth a thousand guesses (as the surgeon said to the physician...)
Old Oct 27, 2020 | 08:46 PM
hattitude's Avatar
hattitude
That would make it super easy....
Good luck... Post up what you find...
Old Oct 28, 2020 | 07:59 AM
back again's Avatar
back again
The nut is not inside the housing . It’s on the outside and is fo locking the light in its correct position. Only the stud screws into the housing by turning the light body itself. Then you hold the light and tighten tension nut. You only unplug the din plug for the process.Hope this helps you.
Old Oct 28, 2020 | 10:34 AM
rb5064's Avatar
rb5064
thank you! I will double check, but memory tells me there wasn’t a visible nut between the turn signal post and bracket. I’ll have to get an inspection mirror and search behind the nacelle to see if there is extra wire stuffed behind there. If so, then that may give me enough to turn the turn signal to back it off the post without cutting wires? It’ll be this weekend before I get to look at it.
Thanks for the input!
edit: I missed the part about unplugging the din connector. I’ll have to locate it. That would make it simple.
Old Oct 28, 2020 | 12:35 PM
bustergut's Avatar
bustergut
OP i.e. rb5064 - in order to continue helping you, we'll need a close-up photo please...
Old Oct 28, 2020 | 06:22 PM
back again's Avatar
back again
Unplug connector and depin it. Been awhile since I’ve worked on a fat boy but you have to take shroud off if I remember. Surely there’s somebody on here that’s done this will set you straight.
rojuwi
Nov 7, 2011 09:50 PM
FXSTC_Bill
Mar 3, 2009 12:24 PM
June Bug
Mar 2, 2009 06:51 PM
SpursDarkrider
Feb 16, 2008 06:53 PM
Chata
May 8, 2007 09:02 PM
