Electrical problem
Old Nov 14, 2020 | 04:10 PM
Mattyboy4201's Avatar
Mattyboy4201
Stage II
Default Electrical problem
I bought a Harley it was burned up I put a new wiring harness in it that had the Delphi security I eliminated that the bike starts up and runs for about 3 to 5 seconds and then dies anybody have an idea and what I can do
Old Nov 14, 2020 | 04:26 PM
Jackie Paper's Avatar
Jackie Paper
There is a lot of Harleys. Need model letters and year.
If it's FI, sounds like fuel pump is not running. It will prime with timer on key on but once CSP reads 20 hits, it runs all the time. If it had a alarm, just can't take it off without writing to ECM and BAS it's removed.
Welcome from Hampton Roads Virginia.
Old Nov 17, 2020 | 10:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Not until you tell us what you are working on, and exactly what you did with the electrical system...
Old Nov 18, 2020 | 08:40 PM
Zanthamos's Avatar
Zanthamos
Likely it still has the original ECU and that is likely security. You will need to follow the password learn procedure to unlearn the password from the TSSM. This will be outlined in your FSM under Factory Security System.
Old Nov 21, 2020 | 09:17 AM
hattitude's Avatar
hattitude
How did you "eliminate" the security....??
We need more info to offer any meaningful help...
Old Nov 21, 2020 | 04:49 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Elecrical, imagine that. Wrong harness, or you missed something.
Last one I did, I missed the color code and got a couple wire crossed.
Bull dog mentality set in til I figures out what I missed.
Good luk with that, patience.
Crash Davis
Oct 17, 2024 06:50 PM
kernwright
Apr 13, 2021 01:47 PM
Portal
General Topics/Tech Tips
Jul 29, 2020 11:50 AM
FLRoadKing
Electrical/Lighting/Alarm
Apr 30, 2017 10:59 AM
bignig59
Aug 18, 2016 08:45 AM
