Key Fob issues
Old Jan 11, 2021 | 09:34 AM
Arnie Trudeau's Avatar
Arnie Trudeau
Stage IV
Default Key Fob issues
My wife's NEW 2020 Softtail 45 miles from dealer to home, put in garage, started a few times, put on battery tender. Went out to start yesterday calls for a code to be entered. NO IDEA WHY? put code from dealer in, started fine, WILL NOT ACCEPT me putting in new code as advised. Every time I have to put code in from dealer to start it. I have changed battery in FOB 3 times, still same issue? My local dealer is closed, anyone here have any ideas?
Old Jan 11, 2021 | 11:16 AM
Capt_Salty's Avatar
Capt_Salty
Maybe dealer gave you the wrong fob?
Old Jan 11, 2021 | 03:40 PM
barneyboy's Avatar
barneyboy
You can start the the bike without the fob present by entering your PIN, but you can't change the PIN without a working fob present. To eliminate the possibility of electromagnetic interference in your garage, start the bike with the PIN. Take a ride to an isolated area free of possible interference. Turn the ignition off for a minimum of 5 seconds. With the fob present, try a restart.
Old Jan 11, 2021 | 04:08 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Really? Owners manual tells ya factory code and how to enter it. Remember that same owners manual had cut out card to put in your wallet, how to enter the code should you ever lose the FOB.
RTFM?
Old Jan 11, 2021 | 04:31 PM
470004's Avatar
470004
I had a problem when I picked up the new SG. The bike started and I had the fob hanging on my keychain.. The next day I went to the garage to start the bike up. It started up without any problems, but I forgot the fob. Tried starting the bike again without the fob nearby and it started. Then I also noticed the security key on the dash was not flashing. Took it back to the dealer and they re-program the fob with the bike. No more problems.
Old Jan 11, 2021 | 04:58 PM
Tampa Fatboy
Dayum...didnt have a bike with a FOB until now. First thing I did was read the owners manual. Lose the FOB, batteries die, what do ya do do?
Theres a cut out card on the manual for your wallet. even tells ya how to change it and write it down on the card in case if you have a limited mind.
Noww, I'm messin with ya
Old Jan 11, 2021 | 05:53 PM
barneyboy's Avatar
barneyboy
RTFM?
FYI. There is no such thing as a "factory code". The initial PIN is established at the dealership level during PDI fob assignment. Every dealership has their own protocol for creating an initial PIN, and it varies by dealership. Your dealer may have written your PIN in your owner's manual, but it doesn't appear in print, wallet cards or elsewhere.
Old Jan 11, 2021 | 06:54 PM
TriGeezer's Avatar
TriGeezer
Are you sure you installed the battery properly? It’s pretty common to put it in wring.
Old Jan 12, 2021 | 12:30 AM
Tampa Fatboy
You are correct theres no printed code in that owners manual. The dealer usually writes it in.
It's my understanding Harley puts a standard factory preset PIN code and it is usually 31313, the dealer may change it to whatever they choose.
Old Jan 12, 2021 | 05:46 AM
Steve Sportster's Avatar
Steve Sportster
Why are you starting it if you're not going to ride it? Not good for your motor as been stated many times on the Forum. Better plan on a trip back to the dealer with the bike.
