Smooth Fender Struts Install
Old Feb 15, 2021 | 04:03 PM
HDJoey's Avatar
HDJoey
Default Smooth Fender Struts Install
Hey Guys
Anyone have experience in installing the drag specialties smooth fender struts? It came with no instructions or hardware, the struts have a threaded bolt attached to the back of it, I cannot use oem hardware because I have brackets and not bolt nuts. It seems to have to be bolted from the inner fender somehow. If someone can help me out please! I cant believe DS did not supply hardware really
2003 Fatboy
Old Feb 15, 2021 | 04:09 PM
HDJoey's Avatar
HDJoey
BTW the threaded bolts that are attached to the strut is the same size as a stock strut bolt, I believe 3/8-16. I cannot simply go buy nuts and attach from the inner fender because the strut holes on the fender is bigger than the bolt, I would need some kind off item to fit in the fender hole in order to reduce its size to 3/8-16 just like the stock brackets do. see pic
Old Feb 16, 2021 | 08:43 AM
MCSarge's Avatar
MCSarge
Just go buy some 3/8 washers or even fender washers and don't use the stock brackets. I have put a lot of fenders on and normally just use chrome allen head bolts and washers and nuts. Just put the fender in the position is needs to be and snug it down. If you use fender washers you might have to bend them to fit the contour of the fender because if you leave them flat and you tighten them in a curved area the flat washer will push the fender sheet metal out Also make sure the bolts on the back of the covers aren't to long so they don't catch the tire on suspension compression. Good luck on your project......
Old Feb 16, 2021 | 08:51 AM
RANGER73's Avatar
RANGER73
Just put a fender washer and nut, you're good to go. If you want to get creative put a sleeve over the threaded part to make up the difference.
But if the threaded part is the same size as the OEM bolt I don't see what the problem is.
Old Feb 16, 2021 | 08:54 AM
eighteight's Avatar
eighteight
[QUOTE=HDJoey;19739814]BTW the threaded bolts that are attached to the strut is the same size as a stock strut bolt, I believe 3/8-16. I cannot simply go buy nuts and attach from the inner fender because the strut holes on the fender is bigger than the bolt, I would need some kind off item to fit in the fender hole in order to reduce its size to 3/8-16 just like the stock brackets do
If it bothers you, just use a short nylon spacer or piece of rubber hose on the new "stud" to fill the space in fender
Old Feb 18, 2021 | 10:29 PM
HDJoey's Avatar
HDJoey
Thxs guys! That’s some good ideas, I’ll try them out, I’ll post some pics of what I use. Thxs again for the help! 🙏
eg78
Jun 28, 2018 02:41 PM
SOA
May 9, 2018 06:42 PM
fatboy1729
Mar 24, 2014 05:10 AM
kozy22
Mar 18, 2011 07:28 PM
whtpshr01
Dec 13, 2008 02:44 PM
