CVO Clutch issue
Old Mar 20, 2021 | 05:50 PM
oldsofty63's Avatar
oldsofty63
6th Gear
Thanks - where did you find that fluid ?
Old Mar 20, 2021 | 06:15 PM
hattitude's Avatar
hattitude
Any good motorsports shop should have it, online (Chaparral Motorsports, Summit Racing, etc), and I bought mine at Amazon, I have Amazon Prime and get free and/or expedited shipping...
I forget now if I used the Motul 600 or Motul 660... both very good products that exceed DOT 3 & 4 specs....
Amazon Amazon
Amazon Amazon
If you want to save some money, you could use a DOT 5.1 fluid. It's still a glycol base (not to be confused with DOT 5 silicone based fluid) but has a higher dry/wet boiling point than DOT 3 or 4. It's like the "high performance" DOT 3 or 4 fluid. It can usually be found at most auto parts stores, it will be a little more expensive than DOT 3 or 4, but less than the Motul brand fluids...
Motul brand fluids are really top shelf stuff and used by many who race their vehicles... it's premium stuff and you pay for it...
Old Mar 21, 2021 | 09:01 AM
Tampa Fatboy's Avatar
Tampa Fatboy
Synthetic brake fluid, if you can find it. Much better than conventional. You may as well flush brakes while you're at it too.
I use a large syringe and pull the fluid through, just need someone pouring the fluid.
Old Mar 21, 2021 | 09:55 AM
hattitude's Avatar
hattitude
I've used a vacuum bleeder, a pressure bleeder, and the old fashion way (pump lever, open bleeder, close bleeder, release lever, repeat)......
The last time I flushed brakes on my bike, I tried the syringe method.... I found it simple, easy, and with inexpensive equipment... I'm sold on the syringe flushing method...
I still use the pressure bleeder for my cars/truck. It seems to be an easier one-man job on those bigger, higher volume systems... But IMHO, the syringe method is easier and less complicated for the smaller motorcycle systems...
HarleyGTP
Mar 12, 2021 09:37 PM
mikear2012
2014-2024 Touring Models
Oct 31, 2017 12:50 PM
bradrosewood
Screamin Eagle CVO Models
13
Jun 14, 2015 01:04 PM
redeye93
May 11, 2013 05:10 AM
mking7
Aug 12, 2011 10:51 PM
