Driving me mad!
Old Mar 15, 2021 | 07:56 AM
Rimbo's Avatar
Rimbo
Default Driving me mad!
Hi all. This is going to sound like the dumbest question probably, but any ideas how I get the lens off the rear taillight/break/indicator of a 2014 Breakout?! I've got the front lenses off dead easily with a flat head screwdriver in the little slot in the lens. However, I've checked and checked and there's no similar slot on the rear ones. I don't want to jam. screwdriver in just in case they're not supposed to come off, but seems a bit mad to me as how on earth can you change a bulb if one goes?? Any help gratefully received.
Thanks
Old Mar 15, 2021 | 08:07 AM
Hecklerboy's Avatar
Hecklerboy
Are these stock lenses?
2:26 show just prying off the stock lenses.
Old Mar 15, 2021 | 08:18 AM
Rimbo's Avatar
Rimbo
Hi - thanks for coming back. I'm pretty certain mine are standard stock, but don't seem to have the slot where you can put the nickel/screwdriver to pop off the lens cap. They're combined brake/indiacator/tail light if that makes any difference?
Old Mar 15, 2021 | 08:23 AM
Rimbo's Avatar
Rimbo
Old Mar 15, 2021 | 08:57 AM
MCSarge's Avatar
MCSarge
A lot of times people will install them so the slot is hidden, either towards the fender or at the bottom. Either way you should be able to take a small flat screwdriver or a pick and pop the lens off.
Old Mar 15, 2021 | 09:16 AM
Rimbo's Avatar
Rimbo
ok thanks - will go and give it another try with a thin screwdriver......
Old Mar 15, 2021 | 12:18 PM
vivid black's Avatar
vivid black
I've got 2014 Breakout they look like those but mine doesn't have led's just regular style bulb. Some one has changed something inside housing.
Old Mar 16, 2021 | 03:36 AM
Rimbo's Avatar
Rimbo
Just to follow up on all this, it appears mine are sealed units (a norm for the EU/UK models) unfortunately.
Old Mar 16, 2021 | 08:35 AM
MCSarge's Avatar
MCSarge
I apologize, I didn't realize you were in England. So does this mean you just have to replace the whole assembly?
Old Mar 16, 2021 | 08:44 AM
Rimbo's Avatar
Rimbo
Yes looks like it. This all started when I wanted to change to smoked lenses. The fronts are fine and I’ve quickly changed those but the rears are solid units, so it’s either a spray job or leave as is it try and find a smoke unit. All good fun eh! :-)
