Why No Aftermarket Risers for 2016 Breakout
Old Mar 16, 2021 | 04:51 PM
DrPlastic's Avatar
DrPlastic
Default Why No Aftermarket Risers for 2016 Breakout
looking to get a set of taller risers (6") for my 2016 H-D Softail Breakout bit cannot find any. Harley does not sell any and neither does Dennis Kirk, J&P cycles or others.
Any help is appreciated.
Old Mar 16, 2021 | 07:33 PM
JohnnyMagic's Avatar
JohnnyMagic
What size bars???
Literally hundreds available. Search " 6" riser for 2016 Breakout"
JM
Old Mar 16, 2021 | 08:18 PM
DrPlastic's Avatar
DrPlastic
Stock 1.25" bars. I did and most of the searches brought up other bikes and not necessarily thebreakout.
Old Mar 16, 2021 | 10:08 PM
JohnnyMagic
Anything with a 1 1/4" bar clamp diameter and the 1/2" x 13 bolt thread should work?
Some don't include top clamps?
1" bars are more common. Harley does step the 1 1/4" bars to 1" at clamp (on some)
but not sure what bars you have?
I ran some take-off Fat Bob bars on mine cause I liked the 1.5" tapered bars.
Ended up making my risers 'cause I needed extra pullback to see my gauges.
JM
Old Mar 16, 2021 | 10:23 PM
1Fordman's Avatar
1Fordman
I have a 2016 CVO Breakout and it comes stock with 5-1/2" straight risers. Only drawback is they're black if you're looking for chrome.
Old Mar 17, 2021 | 07:32 AM
JohnnyMagic
'Thought drag bars are stock also?
Might want to change both?
JM
Old Mar 17, 2021 | 03:18 PM
DrPlastic's Avatar
DrPlastic
JM
Already did. I installed a set of Fat Boy Low bars a few years ago.
Old Mar 18, 2021 | 03:31 AM
roadrunner1414's Avatar
roadrunner1414
I’ve had the same problem looking for risers for my M8 fat boy. Not a lot of options out there for the 1.25 bar that doesn’t look plain.
The great looking curved, blocky or for want of a better term chunky looking risers are for 1 inch bars. I want somewhere in the 4-6 inch rise but also some curve with about a 1.5 pullback in black. I feel your pain, I might have to go a bar swap to 1 inch bars.
Old Mar 18, 2021 | 08:31 AM
JohnnyMagic
https://www.jpcycles.com/product/127...-1-4-handlebar
I am a very fortunate person to have a complete fabrication shop.
The "Wild One Chubby" risers (might) work if you modified them to accept 1 1/4" bar???
My old stock Deuce risers would have been a good rise/pullback for my FXDR with the Fat Bob bar.
There was just not enough material to open them from 1' to 1.5"
Those Fat Boy Low bars look good.
A 6" riser would work (looks wise to my eye)
I bought 2 takeoff bars.
One plan was to just use flat stock and bond, then wrap with carbon.
To make them look like a 1 piece molded bar/stem. (doesn't relate to your project :-)
There are some really inexpensive risers I saw that are black. Slightly curved and came in 1 1/4"?
Will look again.
JM
Old Mar 18, 2021 | 08:47 AM
JohnnyMagic
Krator, is the name on the risers I saw.
They have a lot of options but you have to search.
One site had all the sizes, colors and clamp dia. Not sure where?
I like wider at the bottom and these start small and widen at the bar.
This bike went from very awkward riding position to going 4-5 hours straight no problem.
Could do any long distance ride and feel great at the end.
JM
