Heel/Toe Shifter
Old Apr 10, 2021 | 01:43 PM
brucepancake's Avatar
brucepancake
Default Heel/Toe Shifter
Hey guys I have been only riding for a few years. I always have trouble getting my bike into neutral for some reason. Someone mentioned a heel/toe shifter and I do need a new shifter. The original looks like ****. What are your opinions on great brands and simple? I have spent some time looking and I really just want stock looking but black. nothing fancy. Thanks for your help.
Old Apr 10, 2021 | 03:01 PM
LenBoyLo's Avatar
LenBoyLo
Default Finding nuetral.
First off make absolutely certain your clutch is adjusted properly. ( owners manual or service manual ) Then make sure your primary is not over filled with oil. Oil level should just be at the clutch basket when the bike is upright level. Too high a level can cause drag and keep clutch discs in motion. Check to see if your shifter is sitting loose on the spline shaft where it's mounted. If you think yours is worn out Harely makes black anodized arms for your heel/toe shifter as well as the rod from there to the transmission shift point. Is the rod from shifter to trans adjusted at correct length?
Old Apr 11, 2021 | 03:29 PM
klf33's Avatar
klf33
I can confirm, I can never find neutral other than by tapping my heal shifter down! never knew why, never bothered to ask, I do accept that my bike has its own personality but I am subscribing to this thread maybe there is a solution somewhere!
Old Apr 14, 2021 | 05:03 PM
60Gunner's Avatar
60Gunner
Too thick of fluid will cause clunky shifting and hard to find neutral. Causes the bike to try creeping forward with the clutch pulled too. It's called stiction.
Personally I think the stock 50wt. called for is too thick. Especially in cooler weather.
Old Apr 14, 2021 | 05:23 PM
tibadoe's Avatar
tibadoe
Had to add the heel shifter to my bike. Went with the standard HD one. Took about 20 minutes to install - taking my time. I really missed it on the ride home when I traded in my 09.
Old Apr 21, 2021 | 07:55 PM
Mike Starich's Avatar
Mike Starich
Stage II
Default 2005 v rod heel to toe shifter
Hey guys just picked up a 2005 v rod .. I’ve been trying to find a cheep heel toe shifter for it but Havnt had any luck anyone have any good sites or have bought one?
aquesada001
Jul 4, 2013 10:18 PM
TheDukester
Aug 27, 2012 07:22 PM
namato1
Jul 28, 2011 07:58 AM
leadman
May 25, 2011 11:12 AM
PURK
Jun 8, 2010 05:47 PM
