Accessory power on a Heritage
Old Apr 11, 2021 | 01:21 PM
Warhawk's Avatar
Warhawk
Default Accessory power on a Heritage
Where is the best place to tap into 12v accessory power on a Heritage? 2009 Heritage.
Old Apr 12, 2021 | 09:09 AM
Will Belden's Avatar
Will Belden
For my Heritage, I added this:
https://www.harley-davidson.com/us/e...it;sp_cs=UTF-8
Only comes with one switch, you have to buy more separately.
Powered it from the battery, but now I have a switch. On my handlebars I have this:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
The second switch goes to the passing lamps (because I hated the switch behind the forks). The third used to be wired to the LED lighting that I have since removed.
Though not all current, I wrote up a blog post on it a while back:
https://twowheelsonebike.wordpress.c...o-do-it-right/
It's just part of my habit now to start the bike, turn on the two switches. Turn the bike off, grab my phone, turn off the switches.
Old Apr 12, 2021 | 12:36 PM
Hammerhead Pat's Avatar
Hammerhead Pat
Got a test light? I would use the headlight wire, that way when the headlight is on you will have power and if the light is off you won't.
Old Apr 18, 2021 | 12:45 PM
Warhawk's Avatar
Warhawk
thanks
I was an avionics tech in the Aor Force, I can handle that.
wondering if there is accessory power under the fork cover near the headlight, or do I need to pull the tank? Or ???
Old Apr 18, 2021 | 12:57 PM
Warhawk's Avatar
Warhawk
Thanks, that second option from Amazon is something like what I have in mind, except I don’t need a cigarette lighter plug-in so maybe I can find a smaller one that I can hide out of sight.
thanks, I’ll check out the blog post.
Old Apr 18, 2021 | 03:55 PM
Hammerhead Pat
Originally Posted by Warhawk
thanks
On my 2011 RK, I use an orange wire with a white stripe for switched power( 6'' back from headlight plug ). look around for an orange wire with white stripe and test it....
sherifflittle
Jun 14, 2024 05:19 PM
leftyjm
Motorcycles For Sale
Apr 2, 2021 02:52 PM
hotroddarin63
Feb 26, 2011 12:39 PM
Softail Girl
Dec 28, 2008 09:36 AM
PUBA ONE
Nov 7, 2008 11:24 AM
