Softail not starting. No click
Old Apr 18, 2021 | 09:58 AM
surfer10k's Avatar
surfer10k
6th Gear
Default Softail not starting. No click
Hi everyone. Today I had a ride on my 2006 Softail deluxe. After stopping i could not get the start motor to turn or engage. There was no click. Obviously the bike was in neutral, alarm was off, ignition was on. I did not hear the start motor solenoid click. I got the impression that some saftey switch was stopping the start motor from turning. After multiple tries a nd wiggeling the wire plug near the oil filter, it did start.
I am assuming a faulty switch or bad connection but don't know which one. Have gone through the manuals but cannot find a reference to it.
Any help would be appreciated.THX
Old Apr 18, 2021 | 11:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How old is the battery?
Does the bike have a security system?
Old Apr 18, 2021 | 11:12 AM
hattitude's Avatar
hattitude
"After multiple tries a nd wiggeling the wire plug near the oil filter, it did start."
The "wire plug" near the oil filter is the CPS (Crank Position Sensor)... It's a Hall effect switch that senses the crank position/movement via the flywheel. if it goes bad, your bike won't start. It will usually throw a code, but I've read where it has gone bad without throwing a code...
I'm not saying that is your problem, but since it did start after "wiggling" the CPS wire, I figured I'd pass on this info to help with your diagnosis of your issue.
There's a procedure for testing it, and it's easy to change out..
Here's a video I found by Twin Power that talks a bit about the crank position sensor, shows one on a bike, and how to change it...
This is a commercial for the Twin Power Crank Position Sensor, and while I haven't used one, I would be replacing mine with an OEM HD sensor. It's one of the products where I stick with the HD OEM part. I've had a few bikes and none have needed a CPS... So the OEM, by my experience, is a known commodity and a good unit...
Old Apr 18, 2021 | 11:18 AM
surfer10k's Avatar
surfer10k
6th Gear
Hi,
the battery is one year old and the CTEK charger indicates that it is good. I also tested the battery with a battery load tester and it came out good.
Yes there is an alarm system which was switched off. If I normally try to start engine without switching it off the alarm will sound.
Old Apr 18, 2021 | 11:20 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Does the starter crank the engine when the start button is pressed?
Old Apr 18, 2021 | 11:46 AM
surfer10k's Avatar
surfer10k
6th Gear
So if the CPS would somehow be defaulting would that ensue that the starter would not turn and the solenoid would not click? I read on the internet that the CPS mainly influences ignition timing, so when it is running. Or did I misunderstand that?
Thx
Old Apr 18, 2021 | 11:48 AM
surfer10k's Avatar
surfer10k
6th Gear
No, ignition lights are on (neutral and oil), but when I press the starter button there is nothing at all, not even a click.
Old Apr 18, 2021 | 11:50 AM
surfer10k's Avatar
surfer10k
6th Gear
OK Thanks. Will look into that
Old Apr 18, 2021 | 12:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Alarm and security are two different things, you can turn off an alarm, but you can`t turn off the security system.
Has the alarm always sounded when you try to start the engine?
I sounds like the security system is not enabling the ground for the starter relay.
Old Apr 18, 2021 | 03:23 PM
surfer10k's Avatar
surfer10k
6th Gear
No the alarm did not sound.
Even after the battery tested positive I have decided to change it for a new one. Will let you know tomorrow, Also ordered a new start relay.
rgds
