Adjusting Toe Shifter.
Old Apr 30, 2021 | 07:33 PM
TimN07's Avatar
TimN07
Stage III
Default Adjusting Toe Shifter.
Hello! I’m new here and a new Harley owner. I just retired and am here to realize my dream .
I rode a lot of dirt bikes and my toe shifter was always level with the foot rest. On my 2021 softail standard FXTS, how do I adjust the lever down and will it go level with the foot rest?
Old Apr 30, 2021 | 07:47 PM
gonemad's Avatar
gonemad
Unscrew that nut in the far right of the picture on the shift lever, slide the bolt out. Slide the shift lever off the shaft carefully, and ever so slightly rotate it counter clockwise one spline and push the lever back on the shaft. See how you like it before bolting it back on. Move it as many splines as you want. Bolt it back on good and snug. Maybe even use some blue loctite on the bolt once you are sure you are happy with the location.
You want to be sure you are unhappy with it as it is before attempting this. Mine is jacked up in the air because I wear big honking steel toed boots riding my bagger, and can’t get my foot under it otherwise.
Old Apr 30, 2021 | 07:53 PM
TimN07's Avatar
TimN07
Stage III
Thank you very much. I will do that.
Old May 1, 2021 | 07:44 AM
heybaylor's Avatar
heybaylor
might want to ride it a while before adjusting it .
Dirt bike riding is a lot of standing up on the pegs.
when I rode dirt the levers were angled down for easy reach when standing,and also the shifter was level as to reach with feet pointed level and down.
street riding is 99% on the seat, so levers and shifter moved up for easiest reach while sitting .
hope this helps
Old May 1, 2021 | 08:23 AM
hattitude's Avatar
hattitude
You received some good advice...... As pointed out by others, you can move the shifter as described, to a position comfortable for you...
But I will add, look at the shifter lever in your pic. Due to the curve in that shifter, if you start rotating it so the shift peg is lower in relation to the foot peg, make sure you don't rotate it too much. It would be possible to rotate it to the point where it won't have enough room to downshift the trans before hitting the foot peg mount... That would kind of suck
Feel free to "make it your own", that's part of the Harley experience.....
Enjoy the new bike...!!!
Old May 2, 2021 | 06:32 AM
gonemad's Avatar
gonemad
Here’s a pic from a new member who just bought a project bike that was built many moons ago. HD has been doing that shift lever like that for a long time. I’d ride it first for awhile as has been suggested to see what you think.
Wagondog
Jan 15, 2020 06:19 PM
dozer10
2018+ Softail Models
Apr 25, 2019 02:46 PM
TheDukester
Aug 27, 2012 07:22 PM
danny54
Jan 14, 2012 02:32 PM
Tek74
Feb 13, 2011 12:23 PM
