front stop light switch question
Old Aug 5, 2007 | 03:07 PM
shengte's Avatar
shengte
6th Gear
Default front stop light switch question
Question for you guys, what does the front stop light switch do? Also whats the impact if the boot is ripped? I think I ripped it while changing out the black housings for chrome ones, and I lost the little brass spacer thing. Is it a big deal?
Old Aug 5, 2007 | 03:12 PM
DR.Greenthumb's Avatar
DR.Greenthumb
Default RE: front stop light switch question
It activates your brake light when applying the front brake.If you ripped the boot chances are you broke the switch or broke the end off the plunger so it will be too short to work.When working on the front brake lever or in that area you have to hold the brake lever open with a wedge of some sort.
Old Aug 5, 2007 | 03:18 PM
shengte's Avatar
shengte
6th Gear
thanks for the quick reply FUIRS, I checked the lights when I squeeze the brake, and the lights come on. One of the things I'm worrying about is the weather, or if I wash the bike, if it's going to cause a short due to the broken boot??
Old Aug 5, 2007 | 03:44 PM
Sanford's Avatar
Sanford
If the brake light is still working when you apply the front brake, and you indeed did rip the rubber boot, only a matter of time to replacement. Moisture will get in it and corrode rendering it useless. At least that's what happened to mine.
Scuba10jdl
Nov 24, 2011 07:27 AM
fixedmlc
Jun 16, 2011 10:04 AM
Bobber Jay
May 7, 2009 06:47 PM
jon0808
Mar 2, 2008 07:39 PM
LT753
Dec 26, 2005 09:00 PM
