let the mods begin..............
Old Aug 5, 2007 | 05:50 PM
dlrshort's Avatar
dlrshort
Default let the mods begin..............
I know this has been asked a thousand times before, but could anyone suggest a slip on to replace the stock mufflers for my '07 Deluxe. I'm looking for a nicer sounding pipe but not overlyloud or obnoxious. Also wondering about performance effect and whether or not dealer has to modify any injector settings or change air filter. If not is it a hard install if you do it yourself? Thanks
Old Aug 5, 2007 | 06:07 PM
06Fatty's Avatar
06Fatty
Default RE: let the mods begin..............
I don't have them but I have friends that do....I believe you might be good with a set of Rush Slip ons.
Old Aug 5, 2007 | 06:15 PM
DCS's Avatar
DCS
http://www.epiflex.com/
Here is a link to RUSH Exhaust. They make slip on exhaust and on their web site you can see and hear the different diam. of baffles in their slip ons. I have talked to them B4 and they told me as long as I left the stock air filter on and used a 1.75" diam. or smaller baffle in their slip ons I should not have to have a fuel management system or adjust the EFI. Once you go to some sort of a upgrade on the air filter you would have to adjust the EFI or get a fuel management system. I believe changing to just slip ons is a mater of un-bolting the stock mufflers and re-bolt the slip ons in their place.
Later,
Dan
Old Aug 5, 2007 | 06:37 PM
blackbirdxx's Avatar
blackbirdxx
I third the RUSH mufflers. Easy to install and if you get the small baffles then you won't need to change anything. I got the 2" baffles and also got a Power Commander to smooth things out...All for under $500 in a package deal at fuelmotousa.com.
Old Aug 5, 2007 | 07:00 PM
dlrshort's Avatar
dlrshort
How would you say the small baffle mufflers compare in loudness to stock? It was hard to tell from the clip. Thanks for all your help.
Old Aug 5, 2007 | 07:22 PM
Peg_legs's Avatar
Peg_legs
I like the cycle shack turn outs. I don't have them, but hear they are loud and good for performance.
Old Aug 6, 2007 | 09:23 PM
dlrshort's Avatar
dlrshort
ORIGINAL: blackbirdxx
I have heard and read that a P-C is a good idea even without mods as the '07's run too lean and hot and the P-C can help this. Is this true? If so, is it your experience that the dealer and set this up ok and get and use the correct map or do they just 'tweak' it?
Old Aug 6, 2007 | 09:51 PM
sonar_chris's Avatar
sonar_chris
If you talk to fuelmoto and tell them your pipes and air box configuration they will set you up with a pre-programed PCIII and you can just plug and play. Some fine tuning might be required but the canned maps are usually very close to spot on. You shouldnt have to take it to a dealer or mechanic for install unless you want to get a dyno tune done.
Chris
Old Aug 6, 2007 | 10:04 PM
dlrshort's Avatar
dlrshort
ORIGINAL: sonar_chris
Chris
Chris, where is the unit placed? Does it come with instructions on how to tie it into the wiring harnass?
jhamm
Jan 18, 2015 01:12 PM
bikridr69
Dec 30, 2014 12:57 PM
fatboyartie
Apr 25, 2008 11:29 PM
cowboyfxst
Sep 22, 2007 08:49 AM
Bubba Zanetti
Jul 16, 2007 03:17 AM
