Hot as hell.
Theres no reason to shut the bike off to keep it from going into EITMS mode…its likely harder on the bike shutting it off & on.
I personally solve the problem by taking the F-150 when it gets that hot, with the bikes in the garage waiting for cooler weather-they can take the heat and humidity but riding in those conditions is just not fun for an ATGATT rider like me.
BTW there is a outstanding article regarding heat management while riding, it's been posted in this Forum any number of times. An excellent read, and a search should be able to pull it up.
Actually, it would be strange if it wasn't hotter.......
Obviously, with all engines set up the same/similar, with a good tune, the higher the displacement, the warmer the engine will be.....
Generally speaking...... More displacement = more air/fuel = more power = more heat
My 2016 103" Ultra Classic in OEM form, was much hotter than my 1978 74" FXS shovelhead.... and yet, back then I thought that FXS bike was hot in the summer....
There are exceptions, especially where the tune is very different... My 2016 Ultra Classic runs cooler with a 124" crate motor, dyno tuned by Jaime @ Fuelmoto, than it did with the OEM 103 w/OEM tune... and the displacement and power are much more with the 124" engine..
As for octane, same engine with different octane will not run cooler. The octane affects the spark knock/detonation/pinging of the engine. Higher octane generally allows for more spark advance. If your engine is properly tuned for a specific octane, run that octane. A lower octane could ping, and a higher octane will be a waste of money.... If the bike is not tuned properly, and is pinging..... an additive or higher octane fuel can help with the pinging, but it is not a substitute for a proper tune.... IMHO
