Weird sound when riding
Old Sep 11, 2021 | 09:40 AM
hkb's Avatar
hkb
Default Weird sound when riding
Last night I was riding my Springer when I heard a weird loud humming sound. It lasted about a mile or two at forty miles per hour then stopped. It sounded more electrical than a mechanical sound. I believe the high-beam had cut out when I heard the sound. When I got home, I inspected the bike, and I couldn't see any issues. I haven't ridden the bike today, but I was curious if anyone has experienced a similar situation.
Old Sep 11, 2021 | 10:30 AM
TriGeezer's Avatar
TriGeezer
Humming bird?
Seriously though, that’ll be hard to diagnose over the forum. If it’s electrical, it shouldn’t be speed or even motion dependent. Try to replicate it at home,
Old Sep 11, 2021 | 11:11 AM
hkb's Avatar
hkb
Haha, yeah, I plan on taking it out later today. After thinking about it, maybe it isn't electrical, and I'm in error about the high beam. I suppose a bad bearing could make a high-pitched squeal on a Hog.
Old Sep 11, 2021 | 11:29 AM
TriGeezer's Avatar
TriGeezer
Try to determine if it’s road speed or engine speed sensitive.
Old Sep 11, 2021 | 01:42 PM
hkb's Avatar
hkb
Just put a few miles on it, and it did make the noise again for a few seconds [at 35 mph]; after a half a mile down the road, I continued driving and nothing. I retraced my ride from last night to get an approximate distance when it started; it appears to have been for about one and a half miles before it stopped [25-45 mph].
Old Sep 12, 2021 | 08:14 AM
Cap77's Avatar
Cap77
loud humming sound.
can you tell whether it's coming from front, rear or center?
I don't know much, and even less about electrical, but can't recall shorts, cooking wires or bad connections make a "high pitched squeal"
Humms, buzzes, arc snaps yes, but hi-pitched squeal at particular speeds, I'm thinking mechanical.
does it make a difference if you pull the clutch in or change gears?
any difference in sound if you weave back and forth in your lane?
I doubt I'll be able to help, but know the more specifics you add will help the knowledgeable folks here help you
..L.T.A.
Old Sep 12, 2021 | 10:44 AM
hkb's Avatar
hkb
..L.T.A.
It sounded like it was coming from the front. For the last five years, it hasn't had much use except for the yearly washing and a few trips to the gas station for fresh gas and air in the tires. The noise started after putting on over two hundred miles this week. Today I put a few miles on it without incident.
Old Sep 12, 2021 | 10:49 AM
Uncle Larry's Avatar
Uncle Larry
Welcome To The HD Forums From Michigan, The Home Of Hell And The Greatest Of The Great Lakes States :>)
Old Sep 12, 2021 | 10:54 AM
TriGeezer's Avatar
TriGeezer
I’d suspect front wheel bearings. Sometimes ya just gotta replace the most likely culprit and start from there.
Old Sep 12, 2021 | 10:32 PM
hkb's Avatar
hkb
Overdue for a 25,000 service, I'm waiting till October to have it done.
