Tool kit
Old Dec 7, 2021 | 12:47 PM
WKNDS's Avatar
WKNDS
If you plan to remove/replace the calipers, a 10mm 12point socket / wrench is needed
for the caliper bolts.
Torx bits including a T27. Do not use the T25 or you'll strip it out....
T.
Old Dec 7, 2021 | 12:52 PM
Antonio Molinero's Avatar
Antonio Molinero
Originally Posted by WKNDS;[url=tel:20319295
20319295[/url]]If you plan to remove/replace the calipers, a 10mm 12point socket / wrench is needed
T.
thanks bud!
Old Dec 7, 2021 | 02:40 PM
WKNDS's Avatar
WKNDS
Originally Posted by Antonio Molinero
thanks bud!
No problem. IIRC, the T27 is used on the derby cover screws.
The derby cover is a very common 'item' that folks switch out for
something they fancy...
good luck,
T.
Old Dec 8, 2021 | 03:54 AM
eighteight's Avatar
eighteight
Not high end but covers a lot of ground for $16.00
Old Dec 8, 2021 | 07:19 AM
Sarge Fatboy's Avatar
Sarge Fatboy
Welcome from another 03 Fatboy owner!
All great responses on tools you will find handy.
I forget the job but it added an extra hour because I did not have "retaining ring plier", I ended up getting a 90 degree one which has come in handy on occasion.
Slotted 9/16" long ratchet will make adjusting your running lights a lot easier if you ever need to do that (that allows you to get at the bolt without taking the wires off, I don't have one and it was a pain to get a wrench up in there).
JamesYeager
Harley Davidson Videos
Oct 1, 2017 06:51 PM
MrsDowFire
Jun 20, 2013 01:46 PM
Mike in Oregon
Aug 15, 2009 12:25 PM
sifularson
Oct 4, 2007 06:57 PM
