Check engine light
Old Dec 8, 2021 | 02:45 PM
jambo1989's Avatar
jambo1989
Default Check engine light
Check engine light coming on, along with battery light, red alarm light, and speedometer needle bouncing up and down while I'm riding. Engine runs fine. Seems like the computer is going crazy. Any ideas? Is there a way to check codes? I did put on Vance and Hines slip ons a month ago or so.
Old Dec 8, 2021 | 04:34 PM
Rocking_it's Avatar
Rocking_it
Old Dec 8, 2021 | 04:50 PM
jkinner's Avatar
jkinner
I would start with the battery connections, loose ground or positive(etc) work ftom there. Good luck with it.
Old Dec 8, 2021 | 08:53 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Yes: https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Dec 8, 2021 | 08:56 PM
hattitude's Avatar
hattitude
Crazy electrical stuff can be from sporadic, fluctuating power....
Check the cables/grounds from the battery... when checking any electrical connection, check it for tight connections, possible bent blades/pins, and corrosion on the blades/pins...
Check the battery itself.... (not just voltage but with a load tester)
Check the main power fuse connections ...
Check the ECM connector...
There should be a way to check for codes, but different years have different procedures... I don't recall reading the year of your bike..
Old Dec 9, 2021 | 01:36 PM
jambo1989's Avatar
jambo1989
Thanks for the replies guys, what a great forum! I did check the battery cables and tighten them, and the battery is a year and a half old, seems to be weak when starting, but always starts. I bought it a ORieley, I'll go there and get it load tested.
Old Dec 19, 2021 | 12:32 PM
69cj's Avatar
69cj
When my FLHR did the same thing it was the voltage reg. The stator puts out 3 phase and the reg. converts it to DC regulated.
Norse75
2014-2024 Touring Models
Mar 5, 2020 03:31 PM
Kyle C Kirk
Nov 9, 2015 02:13 PM
chizman
May 15, 2011 04:35 PM
tekeum
Jul 14, 2010 08:55 PM
gatorwalt
Jul 24, 2008 10:26 AM
