Inner Primary Removal (04'FXSTS)
Old Jan 25, 2022 | 10:20 AM
nadajoey's Avatar
nadajoey
Default Inner Primary Removal (04'FXSTS)
hello,
read alot on this fourum about having to remove the oil tank to access the starter bolt. Some have suggested removing the real wheel and access to the rear fender panel. My question, can i do this without having to remove the rear tire?
all feedback welcomed!
thanks
Old Jan 25, 2022 | 05:59 PM
hattitude's Avatar
hattitude
You need to remove your inner primary, correct....??
You are looking for a way to remove the starter, without removing the oil tank, to get off the inner primary, correct...??
I have no personal experience with this..... but there are several who claim to do that by just removing the starter bolts via an extra long allen head for the forward bolt, and an extra long allen head with a swivel for the rear bolt. Then just leave the starter lying on the trans, to remove the inner primary..
No removal of the starter, the oil tank, or the rear wheel.... just unbolt the starter and let it lay there.... I would un-hook the battery, just so the hot lead on the starter isn't live while it's just lying there...
Here's a thread about that technique. Pay particular attention to posts 9, 12, & 13.
https://www.hdforums.com/forum/gener...il-tank-2.html
There are a couple other threads with similar comments...
Old Jan 25, 2022 | 06:58 PM
nadajoey's Avatar
nadajoey
Thanks correct. I am looking to remove the inner primary.
thanks for the info. Looks real tight to fit in anything to access those bolts. But I’ll give it a try and report back!
Markpark44
Aug 12, 2021 10:00 AM
Harman-Davidson
May 24, 2021 11:38 AM
OldWheels
EVO
May 19, 2016 11:32 AM
Skeezmachine
Oct 31, 2014 10:22 AM
2kids3pets
Aug 15, 2010 09:32 AM
