Softail deluxe engine conversion
Old Mar 1, 2022 | 11:56 AM
idomoms32's Avatar
idomoms32
Stage III
Default Softail deluxe engine conversion
Just out of curious, im aware that a 2012 softail deluxe can be converted from a 103 to a 110 engine. But can you tak it from a 103 to a 114 or higher?
Old Mar 2, 2022 | 07:01 AM
eighteight's Avatar
eighteight
You can go 117" ( H-D 117 Hauler kit ) if you remove the engine . split the cases , bore the spigot holes .
And of course you`ll be advised to up grade the crank at the same time
Lot of time and / or money .
Your call
Old Mar 2, 2022 | 07:44 AM
sonny4's Avatar
sonny4
Have a 2010 fatboy and getting ready to install a S&S 110 kit. The full kit they offer requires no modification to the cases. Plan on replacing the crank with a S&S along with proper bearings. Throttle body and injectors are going to be replaced. Transmission needs some upgrades along with the primary. Thought about the 124 kit but believe the 110 will be better choice due to reliability. Cost of project along with upgrades to the bike itself is over the top. Hoping to end up with a solid good looking Fatboy.
Old Mar 2, 2022 | 11:05 AM
idomoms32's Avatar
idomoms32
Stage III
Your call
thanks for the info
mean green
Jan 24, 2024 11:41 PM
JLMann82
Motorcycles For Sale
Nov 30, 2017 12:25 PM
knockerjoe
Aug 15, 2011 03:52 PM
HogDeluxe
Aug 26, 2010 02:29 PM
05 DELUXE
May 30, 2006 05:18 PM
