1995 FLSTN - Loud tapping noise from right hand side
Old Apr 14, 2022 | 07:24 PM
porkr's Avatar
porkr
5th Gear
Default 1995 FLSTN - Loud tapping noise from right hand side
I just purchased this bike and the first two days were the best rides of my life ( which is saying something ).
Today I started the bike and a very loud tapping noise seemed to be coming from the right side of the engine. I also noticed emissions of hot air near the rod shafts.
The bike has an Anders cam but I did not do the install and no very little about adjustments.
Has anyone had this problem ? and fixed it ?
Is there anything an amateur mechanic can do to diagnose/repair the problem or do you recommend a dealer visit ( whose backlog is already 2 weeks ).
Any help appreciated.
Old Apr 15, 2022 | 05:24 AM
eighteight's Avatar
eighteight
Could be be a cam bearing, could be a lifter, could be an adjustable pushrod come loose, could be lots of things
Won`t know till you ( or someone else) opens it up and looks
( What are "rod shafts" ? )
Old Apr 15, 2022 | 06:13 AM
Madison Bill's Avatar
Madison Bill
Pull down on the pushrod collar and remove the upper pushrod keeper. Pull up the outer pushrod tube as shown in the photo and check to see if your pushrods are loose. It sounds like an O ring is not seated properly, check it with your finger. This is a simple operation and you won't hurt anything checking them.
Old Apr 15, 2022 | 06:39 AM
eighteight's Avatar
eighteight
^ Color coded paper clips are reversed on front cylinder
Green for intake / Red for exhaust
Old Apr 15, 2022 | 10:22 PM
porkr's Avatar
porkr
5th Gear
lol - "rod shafts" are rods --I was posting late at night
Old Apr 15, 2022 | 10:24 PM
porkr's Avatar
porkr
5th Gear
and thank you for your input --- It will be a learning experience. I think I will look into the adjustable pushrod angle because this is where the hot air emissions occur.
Old Apr 15, 2022 | 10:26 PM
porkr's Avatar
porkr
5th Gear
are you in Columbus OH by chance ? This is where I bought my first bike -- 1994 heritage.
Old Apr 16, 2022 | 11:17 PM
porkr's Avatar
porkr
5th Gear
thank you. I will find time tomorrow to do this
Old Apr 17, 2022 | 10:11 PM
porkr's Avatar
porkr
5th Gear
Thank you -- I am going to do this tomorrow. I will let you know the results
Old Apr 19, 2022 | 08:51 PM
porkr's Avatar
porkr
5th Gear
I attempted to get the covers off without success today -- I will try again tomorrow. It takes a strong hand to do this...
Z
Engine Mechanical Topics
28
Jun 17, 2018 04:33 PM
kennyg104
EVO
69
Aug 16, 2012 04:40 PM
tohi
Exhaust System Topics
Aug 8, 2012 08:38 PM
1peter
Jun 5, 2009 11:10 PM
jlphillips
Apr 26, 2008 03:16 PM
