16 Heritage Neutral Problem
Old May 5, 2022 | 01:29 PM
Vinny#77's Avatar
Vinny#77
6th Gear
Default 16 Heritage Neutral Problem
When my stock 16 Heritage is not running, regardless of whether the motor is cold or hot, it will very easily falls into neutral. When the bike is running it is very difficult to find neutral. Just did a 3-hole oil change using 20W-50 full synthetic for V-Twin. It did not fix the problem. So I ask, why does the bike have no problem finding neutral when it's not running but it's almost impossible to find neutral when it's running? Has anyone else had this problem and if so, what is the fix/adjustment that's needed? Thanks for your feedback!
Old May 5, 2022 | 04:39 PM
swifty's Avatar
swifty
adjust your clutch.......
Old May 5, 2022 | 04:42 PM
Vinny#77's Avatar
Vinny#77
6th Gear
Thank You!
Old May 6, 2022 | 01:19 PM
vtbigdog's Avatar
vtbigdog
You have too much oil in your primary. The fluid level should be at the bottom of the clutch plate, and that means you might need less oil than what your manual says.
Old May 6, 2022 | 02:03 PM
Vinny#77's Avatar
Vinny#77
6th Gear
Thanks for the advice. The manual calls for 38 ozs. for the primary, which is what I used. I'm not a mechanic. I'd appreciate if you could you explain in layman terms how using less oil than HD specs might contribute to a 'finding neutral' problem. Thanks again.
Old May 6, 2022 | 02:41 PM
vtbigdog's Avatar
vtbigdog
Watch the following YouTube post, particularly the picture of the fluid level. While the ride you have is different than the one in the video the process for all Harley's remains the same.
https://youtu.be/aBYlqcRx-PI
Old May 6, 2022 | 03:13 PM
Vinny#77's Avatar
Vinny#77
6th Gear
VTBIGDOG - The video was an eye opener. He concludes by saying too high a level results in clutch drag and too low can cause overheating. I will be checking the level to make sure it's at the bottom of the clutch plate. If anything, it might be too high. I don't understand why clutch drag would cause a 'find neutral' problem but again, I'm not a mechanic. Thanks again - appreciate the help!
Old May 6, 2022 | 03:21 PM
2500hdon37s's Avatar
2500hdon37s
I think the proper spec should be more like 28oz. Less than a full quart.
Old May 6, 2022 | 03:22 PM
60Gunner's Avatar
60Gunner
Too thick of fluid will cause drag.(stiction)
IM0 20W50 is too thick. Especially in colder climates. Never had an issue and it slides in like butter running B&M TrickShift or any type F ATF.
For motor oil. 10W30 or 10W40 in hotter climates is plenty thick.
clutch drag causes the problem because the plates/discs are sticking together. It can also creep while in gear with the clutch lever pulled in.
Old May 6, 2022 | 03:28 PM
Vinny#77's Avatar
Vinny#77
6th Gear
I'm pretty sure trans fluid is 26oz and primary 36 oz.
