2017 flstfbs vss
Old Jul 10, 2022 | 04:06 PM
Prestone's Avatar
Prestone
4th Gear
Default 2017 flstfbs vss
So I need to change out my vss. Dealer says it's 3 hours of labor to replace it. I am hoping there is a faster way. If there is I would love to know the process so I can just change it myself and save the cost of 3 hours of labor at the dealer.
Old Jul 10, 2022 | 04:34 PM
Bone Doc's Avatar
Bone Doc
If you want to do the work yourself you need to purchase the HD 2017 Factory Service Manual for Softails. The part number is 99482-17. You purchase it through the dealer.
You can also search online for Youtube videos.
Old Jul 12, 2022 | 09:43 AM
hattitude's Avatar
hattitude
It's not hard to do... but access can be complicated and/or tight...
I do not know how a 2017 softail is set up... but on my older softails, the sensor is easy to remove... However getting to the harness connector for the VSS, takes some doing.
It's on the electrical bracket, just forward fo the rear wheel, behind a splash guard. The easiest access is to remove the rear wheel. There is a way, by removing the spalsh guard and sliding it up on top of the rear wheel, where you can get acces, but it's really tight...
I offer the information on how it works on my softails, just to illustrate why it may be booked for a 3 hour repair... AND... to show that you could do it yourself, but you should get the Service manual as Bone Doc suggests...
Good luck with your repair...
Old Jul 12, 2022 | 10:07 AM
WKNDS's Avatar
WKNDS
Granted, the following 'how to' from HDForums indicates application up to 2016, but it may give you extra insight into your 2017.
https://www.hdforums.com/how-tos/a/h...-sensor-412957
hth,
T.
eviltwin415
Sep 30, 2020 02:17 AM
John Bertrand
Feb 17, 2020 11:54 PM
CSS_FXD
Oct 23, 2011 11:05 PM
Fire Guys Road King
Jan 17, 2008 02:47 PM
run2bfit
Sep 16, 2007 12:25 PM
