heat issues
Old Aug 18, 2007 | 06:28 PM
blakday's Avatar
blakday
Default heat issues
checked cylinder head temps after a 50 mile ride a couple of weeks ago. To my amazement both cylinders were around 415 degrees.
Called my dealer and the parts manager wants me to buy a SERT and have bike Dyno tested to the tune of $800.00. Called another dealer and was told warranty should be looked at and not nto ride until fixed.
So called my salesman and he thought the same but wanted to speak to dealership owner about the problem.
Plugs are white and bike is running lean, anyone have any advice or cheaper fixes to the problem?
2007 FLSTC
Stage 1
Se 16 gaugedouble barrel pipes
Old Aug 18, 2007 | 09:02 PM
crock921's Avatar
crock921
Default RE: heat issues
415 hey? that sounds awful high to me.
Old Aug 19, 2007 | 12:19 AM
SmokinEd's Avatar
SmokinEd
I would recommend going with a dynojet PC III, but not sure about the config for your pipes and that is important to which map you select. Sounds like Harley has ditched SE exhaust cause they just cannot produce something to compete with folks like Vance and Hines.
I stripped my SE pipes and put on Big Shot Longs, with quiet baffles, then put on the PC III with a map specially designed for that config, and it is SO NICE!!!
It runs at about 180 - 210 oil temp now, no decel pop and loads of torque.
SERT will so something similar, but is designed especially for SE parts. So the recommendation might be legit, but I don't trust things like this coming out of HD as they have EPA and other limitations that just don't let you get the most out of your bike ...
two cents,
Eddie
07 Heritage
Big Shot Longs
Quiet Baffles
Stage I
PC III
Perrrrrfect.
Old Aug 19, 2007 | 10:21 AM
blakday's Avatar
blakday
Let me clarify, that was 415 degree cylinder head temps using an infrared temp guns seems high to me also therefore my concerns and questions
Old Aug 19, 2007 | 10:38 AM
mafosa's Avatar
mafosa
if your bikes fuel injected, then the heat management system should have kicked in. that will make three attempts to cool down the motor. im in vegas, i was on the strip yesterday. while in hot weather and stand still traffic, my bike got to 275 degrees. the heat managment kicked in, the bike started to idle funny, miss, hesatate and run rough. i was able to get tothe harley cafe to let it rest for a hour. after that the bike ran fine. get a temp. gauge dip stick, their just a rough reference to let you know the temp. your temp it should have blown up. good luck though..
GoateeInTheWind
Mar 6, 2021 01:12 AM
tafdeluxe
The Dyno Room
Jul 25, 2016 06:53 AM
sroc3
May 6, 2013 12:09 PM
chromeh
May 8, 2007 11:39 PM
Jim Dawson
Mar 31, 2007 09:13 AM
