steering head bearings
Old Nov 21, 2022 | 11:09 AM
gerald martin's Avatar
gerald martin
Default steering head bearings
I have a 2002 Harley fatboy, I have put a Frankenstein trike kit on it. There is a bit of wobble to it when I am going, How tight can I adjust the front end bearings? I didn't go with the raked front end but decided to stay with the stock setup. When I looked up the racked bearing install instructions it said to tighten the bearings so the front end will move from side to side easily but tighter than stock. Does any one know if that is the same way for the stock front end? Right now my bearings are set up stock specs.
Old Nov 21, 2022 | 11:16 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I have a Sportster converted to a trike with a Frankenstein raked yoke kit. Although there is a torque setting for the neck bearing the final tightness is not a torque but by doing a fall away test. If you have those details I would check fall away and then just go a little tighter. If that doesn't fix your issue then go just a little tighter again.
Old Nov 27, 2022 | 02:10 PM
duffy8540's Avatar
duffy8540
I put a Voyager trike kit on a 05' 1500 Kawasaki Classic (with no rake added) and it had just a tad bit of wobble if you took one hand off the bars. I just lived with it. Voyager said to leave the steering head bearing alone unless raking the forks. No idea what Frankenstien recommends.
Old Nov 28, 2022 | 02:43 AM
Andy from Sandy
If Frankenstein have raked bearing kits as well as raked triple trees (yokes) then I would expect them to tell you it depends, with some pros and cons of either.
Old Nov 28, 2022 | 08:03 AM
JINKSTER's Avatar
JINKSTER
Add a steering damper (if you don’t have one already)
Old Nov 28, 2022 | 08:41 AM
Andy from Sandy
If after doing the usual changing of caster angle, fall away, tyre pressures, suspension setup then I would consider a damper as a last resort. YMMV. The trike I have here only has a small wobble at around 12mph. A little slower or a little faster and there is no wobble at all. You drive through it so fast it is not even noticed.
General Hangover
Jun 29, 2019 10:40 PM
hardheaded
Nov 5, 2013 08:31 AM
HDFatboyRick
Aug 7, 2010 11:41 AM
hd4evr2008
May 16, 2010 08:29 AM
mentor70
Exhaust System Topics
May 18, 2008 06:12 AM
