Softail deluxe side mount plate light wiring question
Old Feb 13, 2023 | 04:54 PM
heater26's Avatar
heater26
Default Softail deluxe side mount plate light wiring question
Hey guys. I'm installing a kuryakyn side mount plate with led light. I put a softbrake housing on my rear tail light and I want to put the license plate on the side of my bike to clean up the rear fender. I will have it mounted on the forks and I'll run the two wires along the rear forks to under the seat. I have some posi taps I can use to hook them up. I assume I will just run the ground into a one of the black ground wires with all the other ones. I'm not sure what I should tap the run wire into? I have seen some threads that say tap into the blue wire in is in the rear wire harness. I'm just trying to make sure I do ths right. Anyone has any tips that would be great. I was planning to hook it up to the grey wire thays in the rear license plate bulb but I can't find that under the seat...so it must tie into the rear wiring harness in the fender somewhere. It's a 2008 softail deluxe.
