Hi fellas Im new to the forum and Im trying to figure out based on my weight, how many turns on my progressive suspension I should make. Im 300 lbs and with my girlfriend, we weight roughly 450 lbs. Can anyone please help because Im bottoming out constantly??
I am unfamiliar with the Progressive suspension on softails... But at 450 lbs combined weight, you are near the max payload of that motorcycle...
Based on that, I would go to max preload on the shocks, and then if it stops your bottoming out issue, maybe try to decrease it a little at a time until you find the sweet spot...
if it doesn't stop your bottoming out issue, then contact Progressive with your suspension part number and see if there is a heavy duty spring option for those shocks..
Fortunately, I got it figured out and she's riding smooth as can be. The only complaint I do have today is the fact that it's 19 degrees outside and I wish I had slightly better gloves!!! Thanks for the reply brother!!
