Fork leak 2001 fxstd
Old Mar 6, 2023 | 12:53 PM
Charles F's Avatar
Charles F
Default Fork leak 2001 fxstd
I got the cap as tight as I could and its still dripping slowley.. is it possible to lossen the pinch bolt and try and push the fork tubes up or am I going in the wrong direction?? Also can I take the caps off the top of the for tubes and replace the seals or is the spring going to fly out!??
Old Mar 6, 2023 | 01:07 PM
eighteight's Avatar
eighteight
Listen to the gentleman below
He is correct
My advice was wrong
My apologies
Old Mar 6, 2023 | 01:28 PM
Campy Roadie's Avatar
Campy Roadie
Have a look at this
Ronnie's Harley-Davidson | SUSPENSION - FRONT FORK ASSEMBLY W/ STEERING STEM (onlinemicrofiche.com)
Your leak may be one of two places, the plug or the cap. You'll need to loose the fork leg from the top tree (after removing the wheel, fender and caliper) to accurately diagnose where your problem is. The cap is not under spring pressure. The plug that the cap threads into IS under spring pressure.
Old Mar 6, 2023 | 03:35 PM
Charles F's Avatar
Charles F
Are you saying I can't even take the cap off without removing the wheel?
the link was for a parts diagram it didn't have any information about assembly
Old Mar 6, 2023 | 08:09 PM
Campy Roadie
No
That isn't what I said.
Old Mar 6, 2023 | 09:06 PM
Charles F's Avatar
Charles F
Can I remove just the caps on the top of the trees and replace the metal washer and the rubber O rings on the caps and start from there?? I bought a seal kit and fluid thinking I would need it so I have the rubber rings and the metal washers.. I guess what I'm asking is can I remove the drain screw on the forks, take the caps off , refill the fluid, and replace the rubber o ring and the metal washer on the caps without removing the forks or the wheel?? (I don't have a jack/stand)
I appreciate the help by the way it's bike week and it's kinda time sensitive 🥺
Old Mar 7, 2023 | 07:55 AM
Architect's Avatar
Architect
Yes you can remove just the cap and try to change that seal only, good luck.
Old Mar 7, 2023 | 11:06 AM
Charles F's Avatar
Charles F
Oh great! Thanks for the help!
Jackpoticorn
Jan 26, 2021 09:22 AM
Skul5
Jun 25, 2013 07:05 PM
karlkcfi
Apr 1, 2012 03:42 PM
teeboz
Mar 23, 2012 11:09 AM
Beachman
Apr 19, 2010 02:58 PM
