Mr Ed
Old Jul 13, 2023 | 08:07 PM
ecrow0497's Avatar
ecrow0497
Stage II
Default Mr Ed
I have a FXSB 2014 breakout, Gauges not working,, it has a Combination Single gauge.. Digital Speedometer /Analog Tachometer,,
Analog section of gauges are working BUT all Digital read out NOT working,, No gear selection display,, speed display not working, fuel gauge not working and odometer plus clock not working
I have checked fuses(all fine),,and checked all visible wiring .. CAN anyone help with next direction to locate FAULT? (bike has small mileage <15000klm)
Old Jul 13, 2023 | 08:19 PM
kel03's Avatar
kel03
Welcome to the forums from Ontario, Canada, have you checked for codes........speed sensor ?
Old Jul 14, 2023 | 08:47 AM
Longobard's Avatar
Longobard
@ecrow0497
We need a little bit more info. Is the bike new to you? Did the displays previously work and suddenly stop?
I recommend heading over to the new member welcome area and posting an introduction.
https://www.hdforums.com/forum/welcome-area-only-4/
Anyways welcome to the community.
Old Jul 14, 2023 | 02:14 PM
hattitude's Avatar
hattitude
Mr Ed....??
Old Jul 16, 2023 | 06:33 AM
ecrow0497's Avatar
ecrow0497
Stage II
My Harley is new to me BUT i have had bike for 5 months,, was going fine ,,,have ridden 1000+ klms ,,with no problems, then last week both section of gauges suddenly Stopped working,,,No error codes.. have checked fuses, and relays. plus checked pins back of Gauge,, Digital section of gauges Still not working,,,any advice would help?
Old Jul 16, 2023 | 08:50 AM
hattitude's Avatar
hattitude
Forgive me, I am not familiar with the Breakout gauge set up, are we talking about an OEM gauge...?
If all the digital parts of the guage are not working, how did you check for codes..?
Have you done any recent service, repair, or mods that are in the area of the gauge or it's wiring..?
If you have verified that all fuses & relays are good, and the pins to the connectors are all clean, straight, and making proper contact... I would think the issues then has to be with the signals to the gauge from the BCM, the wiring that carries those signals, or the gauge itself.
When you say "not working" do you mean the display is lit, and you can scroll through the categories but they show "0", or the display is not lit at all...?
If you can get access (or purchase) the 2014 Factory Softail Electrical Diagnosis Manual #99498-14, It should tell you how to check the gauge and the signals from the BCM.
https://www.ebay.com/itm/17513702080...MaAkw6EALw_wcB
NOTE: I just noticed you said both sections of the gauge stopped working and now the digital section is "still not working"....
What did you do that caused the analog section of the gauge to start working again?
dragonflyrider
Feb 8, 2016 04:05 PM
Mchad
Electrical/Lighting/Alarm
Dec 30, 2014 08:03 AM
BadBilly49
Apr 27, 2014 08:20 PM
shineybike
Nov 30, 2012 06:28 AM
Tripwire1
Aug 24, 2010 12:53 PM
