Q about the HD Combination Speedometer/Tachometer for Heritage...
Old Dec 29, 2013 | 09:04 PM
dragonflyrider's Avatar
dragonflyrider
Default Q about the HD Combination Speedometer/Tachometer for Heritage...
I'm probably going to be getting one, so the question is, there are at least 3 part numbers that my bike fits the fitment on, but which one should I get?
Black dial is excluded.
there are 74774-11A, 74775-11A, and 70900171A. I want the MPH, and all 3 of them say gauge only in the description on HD's website.
If they aren't sent with the data cable, on the newer bikes, does just hooking them with the cables take care of transferring the milage?
I won't be replacing this myself, it will be by a HD mechanic when I get my bike painted, but I want to make sure I order the right one.
Thanks!
Old Dec 29, 2013 | 09:20 PM
dragonflyrider
and second question is, is this really a worthwhile investment, or it more to look cool and pretty? I've read past threads that say the fuel gauge is more accurate than the one on the left side of the tank. I would love to have the tach right in front of me instead of having to flip through clicks on the stock gauge.
Old Dec 29, 2013 | 09:21 PM
QC's Avatar
QC
70900171A Is KPH and MPH and says in the description and review that mileage is updated from ECM.
74775-11A is KPH.
74774-11A is MPH.
Hope this helps.
I wish the tach were bigger myself. Old eyes, you know.
Old Dec 29, 2013 | 09:27 PM
Bone Doc's Avatar
Bone Doc
74774-11A
Gauge speedometer shows MPH only
74775-11A
Gauge speedometer shows KM/H only
70900171A
Gauge speedometer shows MPH and KM/H
Since you only want MPH then 74774-11A is the one you want.
To answer your second question, yes, it is very much a worthwhile investment.
You get a speedometer, tachometer, fuel gauge, clock, gear indicator, two odometers and distance to empy estimate. You can specify whether fuel gauge or gear indicator are shown. You can also specify a myriad of colors for the gauge backlight, the speedo, the speedo needle, the tach and the tach needle.
Here is the 70900171A on my 2012 Heritage
Old Dec 29, 2013 | 10:02 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
I love mine, easy to read the tacho, the speedo, gas gauge and what gear you're in at any speed when you glance down.
I also love the color combinations though it's a bit fiddly to set it up.
I think it also looks really nice.
Old Dec 29, 2013 | 10:34 PM
Bluraven's Avatar
Bluraven
I have model 70900072A and think it's one of my favorite upgrades.
It's certainly one of the many upgrades that if it broke, I'd replace it with the same thing.
I have no problem reading the tach and the fuel gauge when reading empty leaves me about 1/2 gallon reserve which is pretty accurate as far as I'm concerned.
Old Dec 30, 2013 | 05:11 AM
dragonflyrider
ok, thanks! I guess I'll bite the bullet then, since the bike will be torn apart anyway and will need putting back together, this will be the time to do it,
Old Dec 30, 2013 | 06:04 AM
casbar's Avatar
casbar
I fitted the previous model to my Heritage, mileage wasn't transferred, it went back to 0, so you have be honest when you sell!
Old Dec 30, 2013 | 10:47 AM
jam436's Avatar
jam436
I found the new fuel gauge to be a lot more accurate than the stock cap.
It will take a couple of tankfuls to calibrate accurately.
Also, the new one has all of the same LCD readouts as the stock speedo, except for the tach w/gear display. Sure it has the new analog tach dial, but I still wonder why they went out of their way to remove that one readout... That was the one I always had it set on on the stock one.
You get something like 30-32 miles to decide if you like it, and to make sure it's all working properly - after that it will "marry" the unit to your VIN, after which it will be un-returnable...
Old Dec 30, 2013 | 03:52 PM
Benway's Avatar
Benway
I've got the combo and couldn't live without the tach. I barely look at the speedo, just the rpms..
