1984 Softail swingarm
They share the same part number with a different year suffix: 1984 is #47537-84 and the 1987 is #47537-86. Often, the same main part number, with a different year suffix could mean just a vendor change or minor improvement to the same part, but in this case I think it means an actual part change.
I compared the pictures in the online parts finder. You can see some obvious differences in the way they are built.. They have different axle mount/adjustment types, and use different rear tire splash guards. The 84 version also looks to have an additional horizontal support bar in front of the rear tire portion on the swing arm. That's just what I could tell from the pictures on the parts finder. There could be even more differences.
It's obviously not a Plug n Play swap.
I don't remember the year that the softails changed their shocks. I know with the early softail shock types, it's really hard to find replacements. If this swing arm change reflects that change too, it could mean totally different shock mounts.
I wouldn't buy the '87 swing arm, unless I could bring it to the bike and compare mounts and measurements, and be willing to do some metal fabrication, and/or also switch to '87 axles/adjusters.
Good luck, and let us know what you end up doing...
