Bassani 2.25
Old Nov 30, 2023 | 08:23 PM
Kegan_99's Avatar
Kegan_99
1st Gear
Default Bassani 2.25
I have the bassani fishtails . An I’m wanting to change the fishtail an do steady custom chikla pipes . The bassani headers are 2.25 , the chiklas are 2-1/8 . Will it work or is the anything I can buy to make up the 1/8 in difference? Tia
it’s in a 2018 heritage
Old Dec 1, 2023 | 05:42 AM
eighteight's Avatar
eighteight
In theory you could use an "exhaust adaptor sleeve", if that size is not available commercially you`ll need to visit a custom muffler shop
However, it may add length and alter your mounting point locations.
It also might be less than attractive
Old Dec 1, 2023 | 06:31 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
You might be surprised how well carefully folded and wrapped aluminum foil can work.
Old Dec 1, 2023 | 07:41 PM
07UltraGuy's Avatar
07UltraGuy
A muffler shop should be able to cut you a couple of "sleeves" that have the correct ID & OD to fill the gap.
Slide them over the smaller tube, then push the larger tube over the outside, then clamp away.
somorkc
Jan 1, 2016 10:32 AM
kelton3
Nov 16, 2011 09:31 AM
Jukebox
Jun 5, 2009 11:10 PM
GliderXXX
Apr 10, 2008 03:14 PM
Cdn RKRyder
Jan 22, 2008 05:50 AM
