‘23 Fat Boy-Turn Sig/Tag Relocation Kit
I’m planning to buy/install aftermarket bags.
Thank You
PS-was at Bike Week and saw the Harley brand bags on a 24 Fat Boy at the show. The workmanship is worse than horrible. I won’t buy them-especially at over $1,000.
Will be making the swap in the next few weeks
There were a number of threads I found on here that had info
And the REAR TURN SIGNAL NARROW MOUNTING KIT from Harley (product no longer found)
Also the plate frame from CD & brake/turn signal
Horizontal Motorcycle Plate Frames with LED Illumination (customdynamics.com)
Integrated Fat Boy LED Taillight with Turn Signals for 2018-2024 FLFB/FLFBS (customdynamics.com)
I read the Harley on-line installation instructions. It said to pull the main fuse. When it came to actually splicing in the new wires, it says to refer to service manual.
1) did you do more than pull the main CB when you spliced the new wires?
I can easily unscrew the neg side of battery, but the + pretty much requires removing the battery.
2) I’m looking for a service manual (Clymer) that covers my 2023. What manual do you have?
Thanks again. I love this bike!
Bob
As for the installation, I don't remember much, it was a couple years ago. I do remember it being easier than I thought it would be, you are just extending the existing wires. I soldered and shrink wrapped the splices. I don't think I pulled the fuse.
Whenever doing anything that you need to remove the fender from the strut, just remove one bolt on each side of the strut to the frame first, and loosen the other two so it hinges/lifts up. Then its easy to get at the fasteners for the fender, otherwise the tire makes it a pain.
I have the factory service manual (FSM), you need one! I bought it from a dealer, but you can check Ebay for a used one, or download the PFD on some sites. I took mine to an office supply and had them cut the backbone, and spiral bind it, I can open it and it lays flat on the bench. It cost around $6 to have that done.
Good luck!
thanks again. Be safe.
Bob
https://www.customdynamics.com/led-l...8aAgL8EALw_wcB
Having just returned from Bike Week, I recall seeing countless bikes with yellow headlights. I plan to make that conversion in the future.
Thanks again for the service manual ideas as well. I’ll keep shopping for one.
Winter is over in NoVa!!
Bob
Good luck!
Thanks again for the helpful information.
