Change slip ons, dyno?
Old Apr 9, 2024 | 03:29 PM
RG153's Avatar
RG153
Default Change slip ons, dyno?
Swapped oem slip ons for KW, didn’t get a dyno. Cats are in the oem slip ons. Am I running lean without s dyno and cats removed? 22 lowrider s
Old Apr 9, 2024 | 06:39 PM
Tileman2692's Avatar
Tileman2692
More motor and any upgrades etc. Bike info is needed and Did you change the intake with a free flowing intake ?
Old Apr 9, 2024 | 07:09 PM
hattitude's Avatar
hattitude
Yes.... but....
The word on M8 engines (I don't own, nor have I worked on one) is that they are not as lean from the factory as the Twin Cams were. Many believe you can get away with a Stage 1, higher flowing A/C and mufflers, without needing a tune..
The cats flow better than most people think... so you are affecting the heat felt off the exhaust system, more than the flow through the mufflers.
IMHO... if you are not constantly running the bike at high rpm and high load conditions, you will not hurt your engine.
Of course, anytime you change the airflow, a retune will allow the bike to run its best.....
Old Apr 9, 2024 | 09:20 PM
RG153's Avatar
RG153
Stock 2022 117 Lowrider S. No still stock intake.
Old Apr 9, 2024 | 09:27 PM
RG153's Avatar
RG153
Yes.... but....
i saw a post I can’t find it about having head issues from running to lean without cats on the softail.
Old Apr 9, 2024 | 09:33 PM
cobra23's Avatar
cobra23
I have seen the AFR's on stock M8s. They are lean from the factory due to EPA regs. One of the SE tuners doesn't cost a lot and could improve engine performance.
Old Apr 9, 2024 | 10:24 PM
hattitude's Avatar
hattitude
Yes, a lean running engine can cause engine damage...
I suspect it would take more than just removing cats to cause a condition so lean, as to cause engine damage... I would suspect other factors were at play
The short version....
Part of an OEM tune uses O2 sensor feedback to adjust the tune in real time. This portion is called closed loop
Part of the OEM tune is outside the accuracy range of OEM O2 sensors, and so it does not use O2 sensor feedback. It uses algorithms based on the components of a stock engine. This portion is called open loop.
The low load and cruise areas of the tune are Closed Loop. when riding in Open Loop, immediate feedback from the O2 sensors will keep the tune safe and relatively effective.
The high rpm and high load areas of the tune are Open Loop. They will be leaner than OEM if you increase airflow through the engine. Most people don't spend a lot of riding time in these areas of the tune.
If you ride hard, at high RPM, and race around everywhere.... you should retune.
If you are a relatively sedate rider, with occasional spirited riding, I seriously doubt you will hurt your engine by just changing to non-cat, slip-on mufflers.
As always, it will run its best if anytime you increase airflow, you retune the engine.... That's what I do.
If you have any doubt, retune... it's always the best option...
I am just saying that with only a muffler change, on an otherwise OEM bike, IMHO you don't NEED to retune.
09IronRider
Milwaukee Eight (M8)
Sep 25, 2018 12:22 PM
09IronRider
Sep 24, 2018 01:52 PM
WhereduGo?
Oct 10, 2016 12:29 PM
cooper216
Exhaust System Topics
Jun 26, 2014 07:26 AM
janke
Sep 4, 2011 09:05 AM
