Portable battery tender
Old May 10, 2024 | 06:26 AM
WKNDS's Avatar
WKNDS
Just a thought... This might/might not be a hassle. To reduce/eliminate any
parasitic draw, why not just remove the main fuse ? Reinstall when you want to go for a ride...
good luck,
T.
Old May 10, 2024 | 06:35 AM
cbrenthus's Avatar
cbrenthus
As someone mentioned, a '95 isn't going to have the parasitic draw that newer bikes have, if any. My '94 Ninja has no parasitic draw when the key is off, and I never have issues with the battery (won't start currently, but the battery cranks and cranks). And my 3 year old garden tractor also has no parasitic draw, and I have never put anything on the battery. Sits outside under a cover for at least 4 months during the winter, fires right up in the spring.
If it were me, I would just leave it be and see what happens. If the battery is dead when I try to ride, I'd get a new battery and either start pulling the main fuse or put a quick shutoff on the negative.
Old May 10, 2024 | 07:31 AM
wlwoodruff's Avatar
wlwoodruff
I guess that might be the place to start. My two new bikes (a '22 Sporty S, and a '23 Low Rider S) are good for about 2 weeks, but they have all the new stuff drawing on the battery while they are sitting. I might also look into a lithium battery, as my understanding is that lithiums hold a charge better. Lead-acids don't like to get zeroed-out.
I really don't need another bike, especially one that I will not ride a lot, but damn that thing is pretty . . .
Old May 10, 2024 | 08:10 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I've long had vehicles and equipment, including bikes, that sit for months without running, no tenders in use. Some of them the battery is disconnected, because it's easily accessed. Others just sit turned off. Rarely do I have a dead battery. On those rare occasions it happens, it's almost invariably a several years old battery.
So I'd say you really need nothing. Let the bike sit, ride it when you want, and don't fret about it.
Old May 10, 2024 | 08:26 AM
hattitude's Avatar
hattitude
There is actually a formula to determine how many bikes you need....
X = R + 1
X - how many bikes you NEED
R - How many bikes you currently own
Just sayin'.....
Old May 10, 2024 | 11:38 PM
berfatboy114's Avatar
berfatboy114
I am thinking about buying a very nice, very custom '95 Springer Softail. It's a beautiful bike and the price is right, but this would not be an everyday riding bike -- this would be the bike to break out every now and then for easy cruising on pretty days, parades, etc. So, I would want to keep it on a battery tender. The problem is that while I have well-protected covered parking, I do not have power in the parking area. Seems to me it would be relatively easy to set up a battery tender using a deep-cycle battery, or even a lithium battery as a power source to keep the the bike battery in good shape.
Anyone out there done something like this? Seems like it should be simple, but I want it to be efficient, and I don't want to fry anything.
I run a heavy gage extension cord 80 feet to a Deltran Battery Tender on the FatBoy. The battery tender needs heavier and heavier cords as the distance increases. I think I can go up to 100 feet. Would 100 feet get you to an AC outlet? I have never tried using one of those house batteries that has an AC inverter built into it. Acts just like an AC outlet. Funny thing, I have one out in the garage that I received as a gift about a year ago but never tried for this purpose.
Old May 11, 2024 | 06:21 AM
wlwoodruff's Avatar
wlwoodruff
Thanks, that's helpful info, but I'm living in a condo right now, so I can't run power cords through the parking garage. At this point, if I get the bike I will probably just disconnect the battery and see how long it holds up between rides.
Old May 11, 2024 | 06:48 AM
Cap77's Avatar
Cap77
my bike is never on a tender ('04, no parasitic draw I'm aware of)
I'm a fair weather rider (30% chance of rain, or temps below 65, I'm not compelled to ride) which means in Spring like now, it might sit weeks between rides.
It starts right up
depending how long between rides, you may not need anything and are overthinking a problem that may not even exist
Nevertheless, if a solar powered tender (as mentioned) isn't an option, I'd buy one of those little lithium jump packs.
If not enough juice to start from sitting a couple/few weeks*, I'd jump pack it and get rolling.
bottom line, given my personal experience, If you have a good battery in the bike now, and we're talking a few weeks and not a few months between rides, I don't think you'll have problem whether tender'd or not
ETA...*If not enough juice to start from sitting a couple/few weeks,(with no parasitic draw to speak of) you need a new battery
..L.T.A.
Old May 11, 2024 | 08:24 AM
wlwoodruff's Avatar
wlwoodruff
Yeah, that seems to be the consensus, and you're right, I may be overthinking it. It's just that my newer bikes are good for about two weeks (of course they have all of the electronic crap, so there's that). I'll try letting it sit, and maybe disconnecting the battery.
Thanks, WLW
Old May 11, 2024 | 08:50 AM
Rounders's Avatar
Rounders
Once a month you are probably fine. Probably won't get as long out of battery
Bring a jump pack,and go for ride to charge it up. Again might shorten battery life.
People didn't always use battery tenders. Some is parasite draw of newer bikes. But I think a lot of it is people just got in the habit of doing it. And mob mentality
