103 top end on a 96 inch ???
Old Jun 14, 2025 | 07:24 PM
WKNDS's Avatar
WKNDS
Good info... ! I hadn't seen that before. I'll be saving that.
...snip...
I hate cutting into, or modifying, the OEM wiring if I don't have to.
There is no "cutting into", just unplugging the rear ACR connector and adding a "cover" or blank
to the wire harness side to keep it from getting crud in it. The starter wire is just "tapped into" using
a tap-con that is easily removed.... But whatever - you do what you think is best for you.
I just know for my 103, wiring this way a made big difference...
good luck,
T.
nanook
Jun 14, 2025 04:11 AM
KDUBYA
Engine Mechanical Topics
Dec 13, 2015 10:37 PM
Machinetools1
May 27, 2011 05:05 AM
cycletrash98
Oct 6, 2010 05:03 AM
jcoopercam
May 20, 2009 08:54 PM
