2000 FXSTB speedo not working
Old Aug 13, 2024 | 07:58 AM
Barnoff's Avatar
Barnoff
Default 2000 FXSTB speedo not working
Speedometer was working just fine week ago, when I went on holidays and left bike in garage. Today, I noticed, that speedometer is not working, turning on/off time to time, engine light comes on/off. Any suggestions?
Old Aug 17, 2024 | 11:21 AM
heybaylor's Avatar
heybaylor
my 2003 FB speedo quit along with the self-canceling turn sigs.
motor acted funny at low speed.
reason was the pickup module went south.
easy fix
Old Aug 17, 2024 | 05:35 PM
hattitude's Avatar
hattitude
If your engine light is going on & off, you should have codes. It's not easy on older Twin Cams to read the ICM/ECM diagnostic codes, but if you know how, check for them.
I don't remember a DTC for the VSS on early Twin Cams.
So the code should be from something else...
However, it wouldn't hurt to check your VSS (vehicle speed sensor) anyways, since your issue is one of the symptoms of a failing VSS.....
Sw107
Jun 21, 2022 07:07 PM
miafcowboy
Jun 1, 2020 09:39 PM
timking
Aug 29, 2007 11:57 PM
tommypic
Aug 19, 2007 11:32 AM
